Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 03-12-2013, 03:08 AM
123klee 123klee is offline
P0304
2002 Montana code P0304 light was flashing now solid, swapped coils no change, new plug and wire no change, found air box plugged solid from hibernating mice cleaned out thats when light went from flashing to solid still misefire. I've been told its the injector. Any help much appreciated
Old 03-12-2013, 09:05 AM
Tech II Tech II is offline
Re: P0304
You cleaned out the air box.....did you also pull out the PCM, and check the wire harness? Probably find a nest there also, and they ate the insulation to the injectors there.....
The Following User Says Thank You to Tech II For This Useful Post:
123klee (03-14-2013)
Old 03-14-2013, 05:03 AM
Re: P0304
I checked cylinder number 4 compression was 30lbs, currently there are no coolant or heating issues or coolant and oil issues what could be the problem.
Old 03-14-2013, 10:59 PM
Re: P0304
Wow, 30 psi is not good....should have min of 100 psi on all cylinders....
Leak down test would tell you if it's a valve, piston or head/head gasket.....
