Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 03-07-2013, 01:18 PM
kpost13 kpost13 is offline
1998 Dodge Intrepid
I am having trouble keeping my 1998 dodge intrepid running. Ive taken it in for a tune up basically, oil change and new battery just didnt get new spark plugs bc i was told that since my car isnt over 100,000 miles it doesnt need new spark plugs yet, it only has 65,000 miles on it.
I bought it off an auction in 2011 and its been sitting until about last month bc I just havent been able to keep it running. It starts and runs for about 10-15 minutes and then it cuts off and stop driving everytime Ive driven it. I was wondering if anyone knew what it could be bc ive taken it to several ppl and they all say different things.
I was told at first it was my brake booster but my brakes works GREAT, and then i was told that it was my spark plugs but just didnt know if i should change them, and then i was told it was my altenator and then they changed their minds bc they told me the numbers were reading just fine. And then i was told that i needed my gas tank drained.
If anyone can help me, Id really appreciate it. THANKS!
Old 03-07-2013, 03:58 PM
aleekat aleekat is offline
Re: 1998 Dodge Intrepid
Does it start right back up, or do you have to let it sit for awhile?
The Following User Says Thank You to aleekat For This Useful Post:
kpost13 (03-13-2013)
Old 03-12-2013, 03:03 PM
it starts right back up.
Old 03-13-2013, 02:50 PM
Just recenlty had a throttle body cleaning seemed to be working fine didnt cut off for the past 2 days until today on the way to work also the oil lights keeps flickering on and off, I just dont know whats wrong with the car. Could it be giving out bc of something dealing witht the flickering oil light? Any suggestions?
Old 03-15-2013, 12:52 AM
hundahunta hundahunta is offline
oil flickering light. oil pressure switch may bea leaking, right middle area of engine, also clean the connector and remove with white plug on the oil pressure switch. also for the stalling the most common thing would be crank or cam sensor. I have also changed pcm for this cause.
The Following User Says Thank You to hundahunta For This Useful Post:
kpost13 (03-18-2013)
Old 03-18-2013, 02:59 PM
thanks so much!!
