just got a 90 CRX w\B16...questions...
i just purchased a 90 HF crx w\ B16A motor and i just wanted to know if any USDM b16 parts are compatible with this motor? aftermarket parts as well and Stock parts. like for example...what timing belt do i use? i heard one from a 94 VTEC del sol..is this true? also what type of header for what car? like can i use a 99-00 Honda Civic Si header for my first gen b16 motor? ok thanks for the help...
Timing belt and all aftermarket parts will be the same from any B16A (USDM or JDM).. Its all the same motor.
"The nympho of info, I'm fuckin' what ya heard"
any b-series part will fit for v-tec with v-tec . GSR parts and Type r parts anything will fit besides the manifold from a gsr.
so i can use say a 93 integra gsr distributor rotor and its compatible with my B16 even tho its a B18 motor? thanks for the help...
oh btw...where should i launch my b16 in my crx? my old rex i launched at like 1800 or so. |
Well the distributor can "fit" but then you have to convert it from non obd to obd1. About launching...with good tires and clutch you should dump it around 3500.
I usually launch around 3000-3200ish.. Watch out.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud. |
Oh and another thing...the only distributor that'll work from usdm is the 90-91 integra distributor but u have to break off the third leg.
I changed my cap and rotor on my rebuilt 1st gen distributer, I'm positive you use the 90-93 teg cap.
any 88-91 cap rotor combo will work.
Name: Scott Stable Of Cars I have Owned: 1991 Honda CRX 1990 Oldsmobile Cutlass Supreme 2003 Honda Accord 1998 Chrysler Concorde 2007 Honda Civic 1997 Toyota Camry 1995 Saturn SC2 1996 Ford Taurus 1991 GMC Sierra 2002 Daewoo Leganza 1999 Dodge Ram 2007 Honda CR-V 2003 BMW 325i |
is there any difference with parts from a 94 DOHC vtec del sol and a 00-99 civic si? i need to get my timing belt changed and i'm not sure what to tell the parts guy. i think they are both the same tho right? but when i looked up B16A parts list...it didn't show anything concerning a 99-00 civic si, it showed only 94 del sol vtec and 90-91 integ parts as parts used for a jdm first gen b16. i think saying 00-99 civic si would be easier and less confusing for the parts guy cause there are many versions of the del sol and he can get parts mixed up. what do you guys think? also...my axles broke last night! what type of axles do i need? can i get replacement stock ones or do i need some type of aftermarket ones? ok thanks for the help...
