Old 03-05-2013, 02:37 PM
ltc86's Avatar
ltc86 ltc86 is offline
ASE or shop manual leak down test for court
Going to small claims to get damage paid for, its an older car with mods and a new motor, need to prove value but I don't have a receipt for the motor but I have leak down test results from a shop showing 1% leakby. I would like to bring some kind of sheet from a shop manual or some sort of ase book showing that 1% would indicate a motor in new condition. If someone has a coy of something they could post that would be awesome, I don't think any of the many internet write-ups would work in court.
Old 03-05-2013, 06:09 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: ASE or shop manual leak down test for court
Do you think the instructions for a cylinder leakdown tester would be sufficient? The challenge will likely be more in proving that the leakdown results were measured correctly and didn't involve squirting a bunch of oil down the cylinders or someone just scribbling numbers on a sheet of paper.
-Rod
Old 03-05-2013, 06:13 PM
maxwedge maxwedge is offline
A990 racer
In most courts you will need an expert witness to testify how this is done and what the results mean, also you need to prove it was done to your engine.
