Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-05-2013, 12:43 PM
Pooljunky20 Pooljunky20 is offline
Heat is on but only blows cold air.
I recently bought a 99 eclipse and it only blows cold air. How do I know which part to replace. The radiator had already been replaced. I figure it has to be either the thermostat, blower motor or heater core. How do i find out which one without having to buy all 3
Old 03-05-2013, 01:07 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Heat is on but only blows cold air.
If the blower fan works, it's ok. It does not control temp. When the car is warmed up, check feel the hoses going to the heater core. If they are both hot, it's ok, If one hose much cooler than the other one, the core is plugged. You can try to backflush the core before you replace it. If the stat has not been replace recently you may want to do that also. You also need to make sure that the temp control door is working properly.
Old 03-06-2013, 10:45 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Couldnt have said it better myself
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
