Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 03-04-2013, 08:07 PM
ryan530 ryan530 is offline
ford explorer wont start unless I pump brakes. help
I am having a problem with my 96 ford explorer.
Usually this only happens on warmer days, but after a few starts, my car will suddenly not turn over. I have found that the only solution to starting it is by pumping the brakes about 6 or more times, fast and hard. Its not the battery because all lights and everything work.
Something it may have to do with, I just found out when going to get my car smogged, my monitors reset everytime I turn on/off my car.
I have asked many mechanics and no one knows what's wrong.
Please help. Thanks
Old 08-17-2013, 10:50 AM
ASE AMD ASE AMD is offline
Re: ford explorer wont start unless I pump brakes. help
Ur pcm is bad for not storing keep alive memory.... Ur no start sounds like the relay,solenoid , starter, ign. Switch. Possibly a electrical issue. I'd try jumping the starter at the relay when it don't turn over. If that don't work ur relay or starter is bad.
Tags
explorer , ford , general , problem , service
