Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 03-02-2013, 12:37 PM
fp1529 fp1529 is offline
Front blower not working
I own a 99 Suburban 1500 5.7. The front blower motor stopped working on all speeds so I replaced the resistor, it still did not work. I then replaced the speed selector switch and it started working fine. Three days later I smelled a slight electrical burning smell and the fan stopped working again. I plan on replacing the switch again to see if that is what went bad. Any thoughts on whats causing this to happen? Maybe the motor is going bad and causing the switch to short?
Old 03-02-2013, 01:45 PM
brcidd's Avatar
brcidd brcidd is offline
Re: Front blower not working
Next time it is inop- meerly whaaaaap the blower motor on its housing- if it starts (it probably will) then the blower motor is worn out- anytime blower is inop on all speeds- do the whaaaaap test. Blower armature goes off center due to wear- and lands in a dead spot- whaaaaaping it- moves it back on center and it runs- until it lands in that dead spot again....
same thing works with starter motors and fuel pumps....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 03-02-2013, 02:20 PM
Thanks for the information but hitting the motor did not work. Correct me if I'm wrong but if the new speed selector switch works, maybe the motor is going bad and causing the switch to burn out?
Old 03-02-2013, 04:11 PM
brcidd's Avatar
Well, then put a test light or a volt meter on the leads to the blower motor- with it plugged in-- if you have juice, then bum blower motor...
'99 GMC Yukon
Old 03-02-2013, 04:56 PM
I will go buy a test light. Can you recommend one? Also what wire do I test it on? The purple one?
Old 03-02-2013, 05:47 PM
brcidd's Avatar
Two wires feed blower motor- black is ground, purple is hot- test across these two- if nothing, then either a bad ground or bad source.
'99 GMC Yukon
Old 03-02-2013, 07:03 PM
Cusser's Avatar
Cusser Cusser is offline
They're typically under $10. Think of a clamp lead, a light bulb, and an awl; the light bulb lights when the clamp is connected to ground, and the point touches positive voltage. A DC voltmeter (or multimeter) can do the same thing.
