Old 02-28-2013, 05:08 PM
grt grt is offline
misfire on cyl 3 and 6
i had a guy put my 2000 GP 3.8L on the scanner and it showed a miss in cyl 6 and 3 which share the same coil pack, so I replaced it but it didnt fix the issure, any other ideas?
Old 02-28-2013, 05:32 PM
grt grt is offline
Re: misfire on cyl 3 and 6
also it only runs rough at idle and when accelerating, its runs smooth on the highway, not sure if that means anything
Old 02-28-2013, 05:59 PM
brcidd's Avatar
brcidd brcidd is offline
I would have swapped the coil with one of the others- to see if misfire follows the coil---
Anyway- try swapping wires, then if no help, then have ignition module tested at one of the local chain stores Autozone etc.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 02-28-2013, 06:39 PM
grt grt is offline
where is the ignition module located? Is it common for them to cause a miss in 2 cylinders?
Old 02-28-2013, 08:18 PM
Tech II Tech II is offline
It could be plugs, wires, or ICM......the 3 coils are attached to the ICM.....just use a spark tester to test the output of the 3/6 coil......if no spark and the 3/6 coil is new and ok, then it's the ICM.......
What condition are the wires? Are they original?
Plugs ever replaced with A/C Delco's?
