Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 02-27-2013, 09:29 PM
sirhcsirhc sirhcsirhc is offline
Ford Focus 06 Door Lock Problem
I have a 2006 Ford Focus. I installed a new car stereo two months ago. Afterwards, I tried to open the car using my key as I usually do and it would not open. I have the standard edition and there is only one locking door to enter and exit the car. Thus, I was locked out of the car. I figured out that I could climb through my trunk and was able to unlock the car that way. I tinkered with it for awhile and I turned off the car and disconnected the negative from the battery terminal. I turned the ignition switch twice and then put the negative back on the battery again. I turned the car on and locked the door. I was able to unlock and lock the door for two months. Today the same problem started again. I tried the same solution that had worked last time twice and it did not work either time. What is wrong with my car and lock? How do I fix it?
Old 07-09-2013, 10:34 AM
lion4500 lion4500 is offline
Re: Ford Focus 01 Door Lock Problem
when lock with key or remote and then press unlock with remote or key. the car door will not open up used the handle. I will have to used the key and open the rear hatch back and go to front door door latch and open the doors
Old 07-09-2013, 02:56 PM
Re: Ford Focus 06 Door Lock Problem
lion4500 Thanks for the reply. After months of dealing with this issue I am proud to say it is resolved! The ground wire has to be grounded to the metal around the stereo, not through the car. Once I moved this grounding, the problem was fixed!
