Go Back   Automotive Forums Car Chat > Buick > General Discussion
Old 02-27-2013, 04:10 AM
sparkyrhett sparkyrhett is offline
Water on floor board
Why am I getting water on the passenger floor after a rain in my 1999 Buick Century. It is not coolant. The harder the rain, the more the water. Please help
Old 02-27-2013, 09:19 AM
aleekat aleekat is offline
Re: Water on floor board
Because you have a leak. Seriously. You will have to pull back your carpet. Dry it all down. Get some really cheap baby powder or talc. Sprinkle it on the vertical surfaces. Then garden hose that side. I would start low around the cowling area before moving up to the windshield. The leak will leave "snail trail" to narrow it down.
Old 02-27-2013, 10:10 AM
brcidd's Avatar
brcidd brcidd is offline
Because it is a "W" car-- look for the infamous rubber seal to be halfway off under the air inlet cowl- right hand side- right above blower motor- take cowl off and you'll better understand- the glue dries up and the 2 ft long rubber seal comes off and allows rain water to drip inside-- usually shorts out blower motor resistor (lower speeds inop) after awhile. I've seen it actualy spray water out of the vents before on high speed blower.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 02-27-2013, 11:26 AM
Tech II Tech II is offline
Agree with brcidd.....remove passenger wiper arm....remove half of plastic cowl on that side....see huge air inlet opening(if you look down you will see blower motor)........just above the opening is a metal edge where that rubber dam should be(diverts water around the opening)....either came loose or off...use 3M adhesive to put back in place.....
