Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 02-24-2013, 10:02 PM
Chevy327slayer Chevy327slayer is offline
Stroker crank
If a 350 had a stroker crank installed just the crank what would the displacement be?
Old 02-25-2013, 04:41 AM
DeltaP DeltaP is offline
Re: Stroker crank
Ya can't just change the crank.
Old 02-25-2013, 08:27 AM
maxwedge maxwedge is offline
A990 racer
Re: Stroker crank
What stroker crank, how much additional stroke, you need to research what you are asking here. And yes you would need pistons and rods.
Old 02-25-2013, 04:34 PM
534BC 534BC is offline
Re: Stroker crank
Depending upon deck height and some other clearances a "stroker" crank can be installed. Technically ANY increase could be called a stroker , but commonly it is a large increase that required welding or a crank from another model engine. I agree with above , the key question is "what is your new stroke"?
Regardless of any other disclaimers the displacement answer that you seek is figured the same way as any other displacement (bore and stroke needed) In your case we know the bore of the 350.
Old 02-25-2013, 10:51 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Stroker crank
The formula is π/4(x²yz) where x is the cylinder bore, y is the stroke and z is the number of cylinders. Put more simply:
Bore X bore X stroke X # cyl X 0.7854
ex.
4 x 4 x 3.48 x 8 x 0.7854 = 349.848 (round up to 350).
For you? 4 x 4 x ? x 8 x 0.7854 = ?
The missing variable is the stroke you want to convert.
As others have said, you will need new pistons and/or rods if you decide to do the 'common' stroke upgrade - the 3.75" stroke of the crank on a 400, which with a .030 overbore will yield 383 cubic inches. The longer the rod you select, the more torque your engine will make - but keep in mind the compression height of the piston (this is the location of the wrist pin in relation to the crown of the piston) will change with the stroke. You *could* run the 5.565" rods of the stock 400s and keep the stock 350 pistons, but this increases piston side loading - which is not conducive to life in a performance application.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
