Old 02-24-2013, 09:51 PM
MusicGeek MusicGeek is offline
Is this Battery Leaking? Pic Inside
Hey guys, my car is a 2012 and has 18K miles on it. Today while replacing the air cleaner I noticed that one of the caps of the battery (near the negative terminal on the fender side) looked greasy/oily with crud on it; the other looked clean. Is this battery acid that has leaked and collected grime or could it be grease from the terminal?
Thank you
Old 02-25-2013, 12:29 AM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Re: Is this Battery Leaking? Pic Inside
This really doesn't look like battery acid but if it is , it will have a distinct smell . It looks more like grime from something in that area leaking causing dirt , etc. to build up a film ! At 12,000 miles , I wouldn't think it would look that grimy unless it's been subjected to a very dusty or dirty environment ? If this is a FWD car , the AC compressor is usually in this area ( on passenger side of the engine compartment ) and leaks in that system often lead to this type of build up . Or it could be your power steering pump ( also normally in this area ) leaking ? Is the battery the only component showing this grime or is it also built up in nearby areas ? Did you buy the vehicle new or used ? Did you buy the car lately or have you had it for a while ? Did you get a vehicle history when you bought it ? Have you looked under the car for unusual debris or signs of water damage ? Raise up the trunk liner and look in the hard to reach areas ( such as the spare tire well ) for signs of unusual residue . More info would be helpful particularly make and model of vehicle . Good luck !
" Sometimes I grow so tired "
Old 02-25-2013, 06:13 AM
Thanks for the reply. I bought this car brand new and it has 18K miles. The battery is on the driver side of the car and this particular cap is closest to the fender, I'm not sure where the power steering pump or AC compressor is but I assume they are on the other side of the engine where the belt is. This is pretty much the only area that looks grimy. The battery terminals were coated with grease and the terminal closest to this cap can be seen in the photo. what does battery acid smell like? It's not to dusty here in the north east, just a lot of road salt and sand the last few weeks.
Old 02-25-2013, 06:58 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Have you had the car detailed since you purchased it? Maybe somewhere along the way some engine dressing has been sprayed under the hood and the sand and dust is sticking to the dressing. Some of the dressings I've seen have an oily film. Have you ever had a belt chirp that someone's tried to identify? I suppose it could be belt dressing as well, although as new as the car is I'd hope that's not the case.
I'd suggest you clean it off and see if it returns. I agree that it's probably not a leak from the battery.
-Rod
Old 02-25-2013, 08:39 AM
For some reason my embedded photo disappeared. I've uploaded instead.
Old 02-25-2013, 10:26 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Looks like the typical venting residue from a battery that is not "maintenance-free". Fairly common, but it wouldn't hurt to pour a mix of baking soda and water on it to clean & neutralize it, lest it starts to run down and corrode the battery tray.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 02-25-2013, 10:34 AM
oldblu65's Avatar
People often coat the battery terminal connections with grease to prevent corrosion . That could be what is attracting the dirt , etc. to collect on this particular area ? In the picture , just to the left of the grime build - up , is what appears to be a wire or maybe a vacuum hose ? There seems to be some " flakes " on that item that look like corrosion . Maybe someone ( you or a mechanic ) cleaned the battery posts and some of the corrosion was brushed off the battery and landed on that particular item ?
Old 02-25-2013, 04:37 PM
The posts have never been touched since the factory and no one has detailed under the hood of the car. The spot you are talking about was on the bracket but was not acid.
However, under the bracket might be a different story. I've uploaded another pic and circled an area under the bracket where I am thinking there may have been a leak from the vent cap.
Old 03-14-2013, 07:09 AM
Clive.Bird's Avatar
Clive.Bird Clive.Bird is offline
Doesn't look like battery acid to me. It would have made a whitish sulphate otherwise. Just clean it off and check again in a week.
[Spam link in signature removed by moderator]
Old 03-18-2013, 12:38 AM
Tami.P Tami.P is offline
Doesn't seems like battery leakage. If it is then there are some symptoms of it like vehicle will won't start at all. When you start the car there will be weak or no response with ticking sound. It could be the grease from terminal.
[link removed by moderator]
Last edited by jdmccright; 03-18-2013 at 11:31 AM. Reason: spam link removed my moderator
Old 05-16-2013, 12:33 AM
harbor's Avatar
harbor harbor is offline
As showed in the picture its not a battery acid and you do not need to worry about it. it is a grease which usually puts on installation of new battery if you are not facing any issue just plug it off and clean with acid and Mobil oil mixture and re plug it.
Tags
battery
