Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 02-24-2013, 03:13 PM
nickledimed's Avatar
nickledimed nickledimed is offline
Send a message via Yahoo to nickledimed
Front turn signal
Interesting, I could have sworn I started a thread about this late last year but I cannot find it.
Ok, so here is the scenario: Late last year my front turn signal quit working, the truck said "Lamp Out" so I changed the bulb, issue remains.
So I replaced the socket for the bulb, issue remains.
Then it got cold out and the turn signal started working correctly.
Now it’s warming up again and it started again.
I checked all fuses and relays in the command module.
While checking these I heard a very strange clicking noise that would happen along with the flasher under the dash but it would do a double click Pause double click.
I thought it would be one of the relays in the command module.
So I pulled each one, one at a time but the clicking never stopped.
I think it’s coming from under the module.
Does anyone have any ideas?
08 Equinox LT
Old 02-25-2013, 11:54 AM
jpb53 jpb53 is offline
Re: Front turn signal
http://www.automotiveforums.com/vbul....php?t=1083147
Old 02-25-2013, 06:25 PM
Originally Posted by jpb53 View Post
Thanks, when I did a search as me as the poster it did not show up.
Sorry for the double thread.
08 Equinox LT
Old 02-25-2013, 08:00 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
I just read it so it should be ok, try again.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 02-26-2013, 11:51 AM
JBElmore79 JBElmore79 is offline
I've seen this happen a couple of times before. Try checking the turn signal switch itself. Very possible it could be failing. Dodge, Chevy, and Ford all have that crappy multi-function combo switch and alot of problems tend to arise with those.
