Old 02-23-2013, 11:33 AM
misterkaren misterkaren is offline
96 s10 blazer stalled now wont restart
96 s10, 4.3, spider injector. my wife was driving it home and it stalled out on her, she got it home, barely, I tried to restart it and it ran rough, now it wont restart.....HELP
Old 02-23-2013, 02:39 PM
SleepyHead98's Avatar
SleepyHead98 SleepyHead98 is offline
Re: 96 s10 blazer stalled now wont restart
Sounds like a fuel pump. You got fuel pressure?
Old 02-23-2013, 03:46 PM
I've replaced the fuel pump, spider injector, timing chain and gears, crank sensor, swapped out the distributor with a known good one and the coil......I'm a little on the confused side right now. Fuel pressure was 62 psi
Old 02-23-2013, 11:18 PM
Wow. Sounds like maybe bad gas or Ignition.
Spray Starting fluid in the Air intake. If tries to start, its not the ignition.
May just be bad gas? did she recently refill?
Fuel filter maybe? But doubtful since the PSI is so high.
Old 02-23-2013, 11:30 PM
Thanks will try tomorrow
