Old 02-20-2013, 03:27 PM
AJJ AJJ is offline
Speedometer/Odometer Stopped Working
My husband changed the coolant recovery tank, and when he was done, the odometer is now blank and the speedometer won't work. Help!!?
Old 02-20-2013, 07:41 PM
scubacat scubacat is offline
Re: Speedometer/Odometer Stopped Working
What model year?
Check fuse #10. If he didn't disconnect the battery during that service it might have blown. Also, if it's a 1999-2003, make sure the SCDS (speed control deactivation switch) under the master cylinder has been replaced with the new one. If it's leaking brake fluid, it can cause fuse #10 to blow repeatedly which would deactivate the speedometer like you said.
Old 02-20-2013, 07:48 PM
12Ounce 12Ounce is offline
There is a speed related sensor on the tranny extension, kinda in the area where he was working .... did the electrical connector get knocked-loose?
Old 02-20-2013, 10:32 PM
12ounce - I was thinking that too but would that knock out the entire instrument cluster including the odometer? I have a hunch that they either didn't do the recall or that the dealer just added that fused link and didn't replace the SCDS and they've got brake fluid shorting out fuse #10.
Either way, I'd check for what he said as well - look for any electrical connector that's undone and also check fuse #10.
Old 03-09-2013, 08:41 PM
wiswind wiswind is offline
The switch on the bottom of the master cylinder applies to all years.......Mine had leaked and had been replaced long before the recall came out.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 03-12-2013, 06:23 PM
Windstartled Windstartled is offline
What year is your van? Do you have the all-digital display or the more common analog speedo/digital odometer setup?
2000 Dodge Dakota SLT 4x4 5.9L V8 - Brutal
2008 F150 FX4 5.4L V8 - Wintermobile
2000 Windstar SE 3.8L V6 - Beast of burden
1995 BMW 540i 4.0L V8 - Weirdest car ever owned
