Go Back   Automotive Forums Car Chat > Motorcycles & Choppers > Dirt Bikes
Old 06-07-2003, 06:43 AM
Blue02R6 Blue02R6 is offline
Two vs. Four
I'm kinda looking at getting a dirt bike for mountain trail use, and I was wondering if a 2 stroke or 4 stroke would be better. Also what displacement would you all recomend. I'm mostly looking at Yammies. I've been thinking a yz-250F would be fairly good.
Old 06-30-2003, 08:11 PM
PsychoX669 PsychoX669 is offline
Send a message via AIM to PsychoX669 Send a message via Yahoo to PsychoX669
2
I think for trail riding involing hills and paths a 2 stroke would be the best the pick up is much better and they are ment for it, a 4 stroke is meant for flater riding. 4 do much better on long term over all power, you need quick fast power which you can get better from a stock 2 stroke
ok i saw this smiliyi had to put it on.... cmon why would i need to respent a dogpile of soemone?!?!
gffhgfhhfghfgh HARBLAR
Old 08-29-2003, 09:35 PM
bassplayer bassplayer is offline
Wink
I am very impressed with the Yamaha WR 250F after some free mods to bring it up to YZ 250F specs. Two strokes are just too much to maintain for woods riding. I used to ride an IT 200 but it was made for trail riding and still fouled plugs on occasion and terrible on gas. Very important consideration for long distance riding. The older ITs even had two spark plugs so you could just switch the wire to the other plug when one fouled.
Old 09-11-2003, 09:09 PM
94tegRS's Avatar
94tegRS 94tegRS is offline
I might be wrong but isnt a 4 stroke much better for trail riding. ive always ben otld that with a 2 stroke if you dont keep it wound out all the time you foul many many plugs.
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 10-15-2003, 08:53 PM
riderrw riderrw is offline
A 2-stroke is alot more fun because of the accerlation if you
plan on hitting the trails hard but if your going to sight see
then a 4-stroke would better suit you
Old 10-15-2003, 11:21 PM
94tegRS's Avatar
yeah, if the traisl new though you cant really haul ass through it, ive done it on a 02 CR125 and the result isnt pretty, never wrecked it but S's come out of nowhere and theres BIG trees in the woods, LOL. but i did trail ride it a few times and it is fun, and they are quick little suckers, id imagine the 250 would be REAL fun. I myself am gonna go for 4 troke because although i dont mind working on my own stuff and maintaining them, I dont wanna be rebuilding top ends all the time, and then when im in there id do the bottom too just to be safe, and the guy with the 4 stroke will still be out playing.
current
history:
Old 12-27-2003, 03:24 PM
parrish5o's Avatar
parrish5o parrish5o is offline
Re: Two vs. Four
I'm a die hard 2 stroke fan. I've been getting dumped be YZs since I was 11. The arm streaching power of a 2 stroke is hard to beat, but the new thumpers are very impressive as well, the only soultion, buy both.
CANFIELD STAGEII HEADS SCORPION 1.6 COMP CAM 555/570
GT40 INTAKE STAGEII LOWER 65MM TB PRO-M 75MM MAF
30LB INJECTORS 190LPH FUEL PUMP/ NOS INLINE PUMP
FMS ZT5 CENTERFORCE CLUTCH HURST SHIFTER
ALUM DRIVESHAFT 31SPLINE MOSER AXELS AUBURN DIFF
ALUM RADIATOR MSD 6AL MSD ADJUSTABLE TIMING RETARD
NOS STAGE II 150HP 497@5800 474@4300 11.3@118
Old 12-27-2003, 08:31 PM
dano 360's Avatar
dano 360 dano 360 is offline
I'm also a die hard 2-stroke fan. I have a seriously modified 00' YZ 125 set up for the woods and believe me its alot of fun. 2 strokes are usually a little lighter then 4's and will handle a little better in the tight stuff. They can be tricky in the woods, trying to keep the rpm's up requires a slightly more aggressive riding style where the 4's have more tractable power down low and a smoother power delivery and require a little less effort to stay in the meat of the power band. Todays 4 strokes have come a long way and are excellent trail and moto-x bikes requiring less maintenance then the 2 strokes. If you're going to be in the mountains i would go with the YZ 250f. You will appreciate the extra torque a 4 stroke has when your climbing.
Danny
01'RAM 1500 QC 4X4 5.9, 00' Mopar PCM,52mm Fastman T/B, K/NGen 2, Flow Tech Headers, Magnaflow Exhaust, Accell Cap Rotor, MSD Ignition-8.5mmWires,180*TStat, SkyJacker Hydros & Dual Stabilizers, 2"Daystars, Westin Nerf Bars, D/T-Trac Bar, Eagle Alloy 184's
04' GMC Sierra 1500 QC Z71 Off Road 5.3
99' Durango SLT 4x4
Old 01-07-2004, 09:10 PM
92'rs boy 92'rs boy is offline
Send a message via MSN to 92'rs boy Send a message via Yahoo to 92'rs boy
Re: Two vs. Four
i tell u what i am only a 15 yr onld guy but i know what i like and i like dirtbikes in general and i have rode the yzf400 pretty sweet it flies and it has plenty of power... you can go slow and easy and u can sweep up the races if u know how to ride and especially for the trails it is great because alot of the new 4 strokes keep up wit these 2 strokes.. with these new thumpers u can get alot of torque at the bottom and and mid range pretty much where ever want so if u need the extra boost to get over that big log to get your front wheel off the ground it is there and yes the 2 strokes are fun to ride in trails if u like to be alert and work your clutch hand alot but i would go with the 4 stoke also because u said mountains that is elevation it would probably be easy to adjust the engin to it but i dunno bout any of that.. 2 strokes can get up hills but it is still easy from what i've found with a 4 stroke becuause with a 2 stroke u get that wheel spinnnin jus to fast and the four stoke stays steady and u get a good steady ride up.. thats my two cents.... sean
Old 01-10-2004, 10:53 PM
2strokebloke's Avatar
2strokebloke 2strokebloke is offline
In Stereo where available
Re: Two vs. Four
I say 2-stroke all the way. It's lighter, easier to maintain (no valve train, no changing of oil), good pickup - and a sound that's music to my ears. For lots of uneven riding it's good.
A four stroke is a bit heavier, but offers better bottom end torque, but require more maintenance, and has more parts to break.
It really just comes down to preference and compromises, do you need low end torque? do want a lighter engine? Do you want to change oil? Or do you just want to mix some into the gas tank?
I'm devoted to 2-stroke power no matter what sort of machine it's in, for a single cylinder engine it's smoothness of torque, light weight, and power for displacement are hard to beat.
But that doesn't mean it's always the best choice.
Support America's dependence on foreign oil - drive an SUV!
"At Ford, job number one is quality. Job number two is making your car explode." - Norm McDonald.
If you find my signature offensive - feel free to get a sense of humor.
Old 01-15-2004, 11:56 PM
uts uts is offline
2 stroke for sure I say. They are actually easier to maintain. Who cares if they foul the odd plug just wack a new one in. The power is heaps better and you can get a lot of bottom end out of a 250 or 500. Though beware a 500cc 2 stroke is only for the hard core especially a CR500. You do have to rebuild the top end a lot more often on a 2 stroke though(not as often as a dealer will tell you though) but it is very easy.
Good luck
Old 01-22-2004, 09:08 PM
calgary_redneck calgary_redneck is offline
Re: Two vs. Four
I have to disagree 4 stroke is the only sencable solution not only do you have a decent power curve but the engine has a much longer live span. Most of the net 4 strokes out are every bit as powerful as the 2 stokes are and only slightly heavier. Go with the 4 stroke and get the good fuel economy got torque curve long engine life and quitier engine operation and no premixing.
Old 02-12-2004, 07:35 PM
volcomrider volcomrider is offline
Re: Two vs. Four
Ok i have a 2 stroke and it is awesome in pretty much everything. The only thing i ever had to do to it to make it better at trails is gear it down to a 50 tooth sproket (for easier technical riding). Now its pretty much perfect (for me). Oh ya the gas rumor is not completly true. My 2 stroke 80 goes about 70 miles on 1.5 gallons. I know the four strokes get even better but 70 miles is alot of riding. So i say 2 stroke all the way.
Old 04-15-2004, 08:00 PM
goinbig goinbig is offline
Send a message via AIM to goinbig
Re: Two vs. Four
I would definatly have to say 4 stroke if you are looking at mostly doing trail riding. People always say that 2 strokes are faster and everything, but my KLX 300 (which doesn't have a ton of mods) will beat a 250 off the line, and go up to about 100mph. WHile in the sand it is not as good, but on the trails, nothing beats it.
Old 04-15-2004, 09:29 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Two vs. Four
Okay folks, look at most 2 strokes these days. They are motocrossers. Race bikes, not trail machines! 2 strokes are less forgiving, less low end torque, peaky powerband and less easy to ride than a 4 stroke, especially in difficult terrain.
The 4 stroke is the better trail machine, the 2 stroke (usually) is the better race bike.
