Go Back   Automotive Forums Car Chat > Chevrolet > Aveo
Old 02-19-2013, 06:43 PM
phipps phipps is offline
Airbag Light
My son's 07 Aveo has the airbag light on. It came on after he drained the battery and we had to jump the car (not sure if that's the cause or just a coincidence).
We took the car to our mechanic and he said there were no codes registered and when he tried to reset the light he wasn't able to.
Any thoughts on what the problem might be? I'd like to avoid a trip to the dealer if possible, but that may be unavoidable.
Thanks!
Old 02-23-2013, 08:29 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Airbag Light
Thanks!
If air bag light on it will not deploy air bag in case of accident.
Could be a spiked SIR bag computer from jump starting.
Disconnect neg. battery cable for 10 minutes and hook it back up.
If that does not fix it find a good capable air bag repair shop or dealer.
And get it fixed.
MT
The Following User Says Thank You to MT-2500 For This Useful Post:
phipps (02-23-2013)
Old 02-23-2013, 09:39 AM
Tech II Tech II is offline
Re: Airbag Light
I agree....that is about your only option.....
Make sure the key is out of the ignition....remove neg cable first , then positive.....now hold both cable ends together(or jumper them together...leave like this for a couple minutes...now reconnect to the battery, pos first, then negative.....if there is corrosion on the cable, clean first before installing...if bolts are corroded, just replace them....
If this doesn't reset the airbag module and the light comes back on, you really can't do anything without knowing the code......this should be left to a garage to work on.....
Sometimes, it's as simple as a connection at one of the SIR harnesses.......simply taking it apart, and reconnecting it is all that is needed(worse case scenario, special contacts have to be replaced, or even the whole harness connector).....but there are many connectors....a specific code would point you to the right connection......however, don't recommend you doing this without following proper procedures to disable the SIR system....
The Following User Says Thank You to Tech II For This Useful Post:
phipps (02-23-2013)
Old 02-23-2013, 09:44 AM
Thanks. I'll try disconnecting the battery and see what happens.
What does jumpering the pos/neg cables do?
I've had it to a mechanic but he didn't see any codes. Looks like I'll have to take it a dealer if this doesn't work.
Old 02-23-2013, 10:32 AM
MT-2500's Avatar
AF - Advisor
Re: Airbag Light
You can spike a computer if cables crossed or hooking up positive cable wrong.
Only disconnect neg. first and hook it up last. after connecting positive .
MT
Old 02-24-2013, 10:21 AM
What's the reasoning behind touching the pos/neg cables together after they're disconnected?
Draining residual charge?
Old 02-24-2013, 10:35 AM
Re: Airbag Light
By doing so, it resets ALL the modules in the car.....which is about all you can do since DIY'ers don't have Tech II scanners in their back pockets.....in fact, neither do I....
Old 02-24-2013, 10:59 AM
MT-2500's Avatar
AF - Advisor
Re: Airbag Light
I did not say to do that.
I said disconnect neg. fIrst AND HOOK IT UP LAST.
AFTER POSITIVE CONNECTED.
MT
Old 02-24-2013, 06:33 PM
Tech-II suggested holding or jumpering the pos and neg cables after they were both removed from the battery.
I have never heard of this and was asking him why he suggested that.
Old 02-24-2013, 07:52 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Airbag Light
That is correct. By disconnecting both cables, then touching and holding the two ends together, you will deplete all the capacitors in all the modules. If the light comes back on, there is a code stored. Your mechanic may not have a scanner that's able to read air bag codes. As Tech II stated, it may be as simple as a connector, or the SDM may need replaced. Either way, the repairs should be done by a shop capable of doing air bag repairs. Don't want to take any chances with this one.
