Go Back   Automotive Forums Car Chat > Ford > Contour
Old 02-19-2013, 06:15 PM
mopar man's Avatar
mopar man mopar man is offline
96 ford contour charging issues
I have saw a thread on here for a 98 but it didn't help at all the battery alternator mega 175 amp fuse is all brand new I have gone through all the fuses and I cant get it to charge and I checked the ground side and all the grounds on the car for the charging systems and I am almost at my wits end with this car any help would be greatly appreciated
I stepped on a Cornflake, and now I am a cereal killer.
Old 02-19-2013, 08:37 PM
DeltaP DeltaP is offline
Re: 96 ford contour charging issues
Is the charging light on? Did you check the 20 amp ignition fuse,(#4 fuse I believe), in the under hood power distribution box? Has the battery been fully charged and tested? Battery open voltage should be 12.5 volts or better. Is the charging light on while running? Run the engine around 2000 RPM with the headlights on and measure voltage at the alternator B+ terminal. Should be 13v or better. Then measure voltage at the alternator feed terminal on the starter relay.There shouldn't be more than a 1/2 volt difference. If so repair the high resistance connections or open in wire between the alternator B+ and starter relay. If the alternator still doesn't charge enough put a jumper between the "F" terminal screw on the regulator and the alternator case. If the output voltage increases to 13 to 15 volts replace the regulator. If output voltage doesn't increase to at least 13 volts replace the alternator.
The Following User Says Thank You to DeltaP For This Useful Post:
mopar man (02-22-2013)
Old 02-22-2013, 01:13 AM
mopar man's Avatar
thanks for the help i checked the fuse and and yes the light is always on or was i was checking the alternator over again and someone cut the B+ line leading to the battery it was cut to where i could not see it i rewired it back together and it is charging fine now thanks so much for the help though it was really appreciated
Old 02-22-2013, 07:29 AM
Thank you for posting the result. Glad you got it fixed.
