Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 02-19-2013, 01:10 PM
010175 010175 is offline
electric starter/starting issues
1998 suburban, owned it for 15 years, 220,000 miles, new battery, starter last year, cleaned connections by disassembling all parts at battery! The bolt out, the round lead thick washer out, ect. The problem is when I turn the key at times it acts like a dead battery. Jump starting works all the time. If I go from off to start with the key sometimes it will not turn the starter. If i go from off to on, wait 20 sec, then start, it will start. Is there a starter relay somewhere not on the starter that is going bad? What is the chance it the ignition switch? I know its not the battery or the connections at the battery! Any other ideas would be help full.
Dave
Old 02-19-2013, 05:48 PM
777stickman 777stickman is offline
Re: electric starter/starting issues
Start relay in the underhood fuse block. Ign A fuse #6 40a in the same place. Crank fuse #8 10a in the dash fuse panel. Could be any of these or the ign sw or the Park, Neutral Safety sw. 1st check for 12v on the Purple wire at the starter in the "crank" position. If it's there most likely another starter replacement.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
The Following User Says Thank You to 777stickman For This Useful Post:
010175 (02-21-2013)
Old 02-20-2013, 08:47 AM
j cAT j cAT is offline
Dave
I would load test the battery , since a jump start stops any cranking issues.
at this amount of mileage replacing the ignition switch and the crank starter relay is a good idea .
any corroded wires should be replaced. the corrosion can work into the connector fittings reducing amps required to drive the starter.
the other Item would be the alternator output should be checked under full load. it is possible its only putting out 50% power as the diodes start to fail. also on shutdown will suck down the battery power [leakage of current].
The Following User Says Thank You to j cAT For This Useful Post:
010175 (02-21-2013)
Old 02-25-2013, 08:28 PM
Well getting back with what was wrong. It was a losses starter cable at the starter. Replaced the starter last year and did not tighten the cable enough. That was it! Dave
