1986 chevy caprice
hey guys im new to this . this is my first caprice and it is a 1986 chevy caprice. i think my transmission is going out because when it gets to hit 2 gear once it goes into 2 the car tugs and goes.im guessing i need a new transmission but i do not know what kind of trans. my motor my mechanic and a search i did said that it is a 5.0 v8 4bbl and it does have a carberator on it. can you guys help me on this please and thank you
Re: 1986 chevy caprice
I would bring to a transmission shop experienced with this old transmission. you could have a even lower quality transmission in it . this would be to 200R4. GM used a 305 CU engine. this was designed and used as a lower cost replacement to the 5.7L 350 cu engine. the 350 cu is the strongest more reliable power plant . check the fluid levels when the transmission is warmed up driving it for several miles . make sure its just below the fill mark, being this old you will require a complete rebuild. parts are available to overcome the weak parts GM used to improve reliability . cost will be about $2,ooo. |
Make sure the TV (throttle valve) cable is adjusted properly. If it is not, it can make the trans not shift properly. do a search for the adjustment procedure. It is not difficult to do and requires no tools to do it.
I would start there.
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip, 1989 Mustang LX 5.0 5sp convertible 1992 Camry LE 2.2 1996 Suzuki RMX250 I'm a victim of circumstance [ |
The car may have either a TH700-R4 or a TH200-4R. Look inside the trunk lid - there is a sticker with a bunch of 3 digit alphanumeric codes on it. It will say "Service Parts Identification" on it. Look for M codes - MW9 indicates TH200-4R and MD8 indicates TH700-R4 / 4L60. MX0 is simply 4 speed auto overdrive, which both of these are.
A visual inspection will show a TH200-4R with the presence of a long square/trapezoidal oil pan with two sumps; a TH700-R4 will have a rectangle shaped pan.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
Here is a procedure to adjust the TV cable.
When i drive it after it hits 2 gear and i floor it it does a weird noise like if its gulping sumthing and then it turns off on me
When was your last complete tune-up including plugs, wires, fuel filter, pcv valve, breather, air filter, dist cap and rotor? Start with the basics then make sure the TV cable is adjusted properly using the procedure posted by silicon..
