Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 02-18-2013, 06:16 PM
tirwin88 tirwin88 is offline
2004 Chevy Impala
While driving today all of a sudden the heat stopped working. No air coming out at all. I tried the AC, the defrosters, the floor heat, and nothing came out. When I switch from vent to floor to defrost I can hear a humming noise like it is switching over but the fan never starts. Is this a bad fan motor? I did some searches and resistor came up alot but it seems it would still work somewhat if it was the resistor?
Old 02-18-2013, 06:49 PM
maxwedge maxwedge is offline
A990 racer
Re: 2004 Chevy Impala
The blower it self could be bad, check for 12v at the connector if ok, the relay/resistor is the usual culprit, up behind the glove box on the blower case. watch for burnt connector at the relay also.
Old 02-22-2013, 12:39 PM
SierraK1500's Avatar
SierraK1500 SierraK1500 is offline
Exclamation Re: 2004 Chevy Impala
I agree with Maxwedge.
I have a 2005 Impala that had the same issue. You will hear the motorized
vents operate but the air will not flow. On the blower itself which is located under the dash, under the glove box, will have a white connector with a blue and red wire going to it. Or what colors they used in your year.
The resistor is mounted in the plenum. They used plastic welding to hold it in place. Disconnect the connector from the motor and turn the blower switch on high. That will not heat the resistor. Use a meter or test lamp to see if you have 12V present. If you do , then you have a bad motor. A new motor is about 75-80 bucks. That has the fan mounted also. I got lucky with a junk yard motor.
There are 3 10mm hex bolts holding the unit in place. In this time you may want to replace the cabin filter which is on the passenger side under the cowl.
Good luck and keep us posted.
John
Happiness is driving a Chevrolet!
