Old 02-17-2013, 02:55 PM
shovelrog shovelrog is offline
2001 Lesabre idle speed
Is there a way to raise the idle speed on a 2001 Lesabre 3800 engine? It would smooth out my idling in gear shaking I'm experiencing. It's probably around 600-700 rpm in gear with foot on brake now. Raising it to 800-900 seems to smooth things out.
Thanks,
Old 02-17-2013, 03:39 PM
enslow enslow is offline
Idle speed is not the problem.
When was the last time you did a tune-up? Also, if your UIM is failing, that could cause a miss.
I would do plugs and wires first, and go from there.
Sent from my GT-P3113 using Tapatalk HD
Old 02-17-2013, 03:44 PM
Tech II Tech II is offline
Re: 2001 Lesabre idle speed
Actually, on a fully warmed up engine, idle speed should be around 650 in gear....
You can change the idle screw, but that may set a tps code, and may create harsh shifts.....I would clean the throttle plate and bore and the Pintle of the IAC valve, and the mating passage way of the valve, first....
Could also do a quick check of your air filter, and possible vac leaks...
Old 02-17-2013, 04:40 PM
Plugs & wires were just done. I looked into vacuum leaks a little, the large line to the power brake booster was the only vacuum hosed item I found. It seems smooth without a miss and only gets to vibrating when in gear. You can hear it in the dash rattling and feel it in the floor, it was fine with the wore out engine & tranny mounts. Now that they've been replaced it surfaced.
Old 02-17-2013, 06:05 PM
I just cleaned the IAC and that seemed to cure it. The idle in gear is much smoother and a little higher.
Thanks a bunch!!
