Old 02-17-2013, 04:45 AM
giorgio959 giorgio959 is offline
eletrical issue on grand caravan
hallo to everyone,
can somebody explain to me about issue on grand caravan 1996 happen
while driving all one time I hearing a clicking noise inside dashboard and abs+airbag and heather control they stopped to work all in one shot .
please let me know if you know coud be happen to mine van .
thanks
Old 02-17-2013, 07:25 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: eletrical issue on grand caravan
The only power connection to all three system is the ignition switch. Try wiggling it to try to duplicate the problem. The spring return from start to run may be weak not letting it completely return to the run position after starting.
If it's not power related all three systems are on the CCD data bus. Try disconnecting the negative battery cable a few minutes to reset the bus.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
