Go Back   Automotive Forums Car Chat > Cadillac > Eldorado
Old 02-15-2013, 04:13 PM
Eldorado95 Eldorado95 is offline
Air Pocketes in Coolant Line
How serious is the possibility of air pockets in the radiator line?
A hose on my radiator blew off, draining my antifreeze. I put the hose back on and filled the radiator back up. I took my car out for a few minutes and it seems to be running fine. Should I be worried about air pockets that could have formed ? Any info would be appreciated.
Thanks in advance.
-95 Eldorado 180k mi
Old 02-15-2013, 07:19 PM
maxwedge maxwedge is offline
A990 racer
Re: Air Pocketes in Coolant Line
Are there bleeders in the cooling system, if not leave the cap off overnight with the front of the car elevated somehow.
Old 02-16-2013, 01:40 PM
aleekat aleekat is offline
With your heater set on max.
Old 02-16-2013, 07:26 PM
A990 racer
Question Re: Air Pocketes in Coolant Line
Are suggesting he let it run all night with the heater on?
Old 02-16-2013, 07:28 PM
No. Start car, turn heater on full max. Shut off. If any air in the heater core.
Old 02-17-2013, 10:15 AM
A990 racer
Ok, thought so.
Old 02-22-2013, 06:38 PM
vitalmuncie vitalmuncie is offline
some cars have bleeder valves for the coolant. I wouldn't worry about it, the heater is probably the main concern, as with alot of american made large cars the engine should be below alot of the coolant hoses and will pump the air pockets away from the critical engine parts. just check the coolant level occasionally.
-dave
