Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 02-14-2013, 08:48 PM
tinkering's Avatar
tinkering tinkering is offline
In the 200 Club
Question Oil pressure sending unit location and socket size?
!993 TransSport 3.8: Where the heck is the oil pressure sending unit, and what is the best way to access it? What size of OPSU socket does it take; 1", 1 & 1/16", or 1 & 3/16". Do I need the 3/8" or 1/2" drive; extra deep or other wise? The van has a gauge on the dash.
Old 02-15-2013, 02:56 AM
WelmoedJ's Avatar
WelmoedJ WelmoedJ is offline
Re: Oil pressure sending unit location and socket size?
Very difficult to find:
You will have to take the right hand side front wheel and splash cover off.
It's just above the oil filter, but not easy to see.
It's mounted vertically on top of the oil filter but it's a bit obscured by the balancer and belt.
Find the wireloom to it and that will guide you.
You may also be able to see it from above between belt and engine block.
There's no space to use a socket and ratchet spanner.
Should you need to remove it you will need a spanner M27.
As there's little moving around space, you will need a spanner with a short arm.
I purchased a machine spanner (cheaper) and cut off about half the length of the arm.
That will give you enough space to move the spanner around.
Welmoed
De Lorean DMC-12 1981-11
Toyota Prius III 2009-07
The Following User Says Thank You to WelmoedJ For This Useful Post:
tinkering (02-15-2013)
Old 02-15-2013, 08:12 AM
tinkering's Avatar
In the 200 Club
Talking Re: Oil pressure sending unit location and socket size?
Thanks a ton, I will get after that.
Old 02-15-2013, 03:56 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Old 02-16-2013, 07:44 AM
LMP's Avatar
LMP LMP is offline
diagram above is relevant of the 3.1.....(Vin D)
No clear picture for the 3.8 but these from the mechanical book show filter area...hidden at the back of the engine. And sensor ...http://www.avigex.ca/xport/oilpressuregauge.jpg not shown .. is near the filter adapter.
www.avigex.ca/xport/oil2.jpg
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 02-16-2013, 10:21 AM
gmtech1's Avatar
Yep, thats a "whoops" on my part. Sorry for the confusion.
Old 02-16-2013, 01:28 PM
LMP's Avatar
LMP LMP is offline
Well GM forgot some when going from the "only 3.1" to the "also 3.8" ...a few pages even show diagrams relating to the north-south engine with the transmission in line with the engine...that's a "whoops" on their part
