Old 02-14-2013, 01:19 PM
shovelrog shovelrog is offline
2001 Lesabre TSB info needed next step in vibration search
I've replaced all transmission & engine mounts on my 2001 Lesabre, now I get severe vibration Idling in gear. The Anchor mounts I used are suposed to be hydraulic. I came across TSB # 02-07-30-008 Feb 02. Can someone shed some light on this TSB and post the remedy/fix?
Thanks,
Roger
Old 02-14-2013, 02:35 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2001 Lesabre TSB info needed
Document ID: 857448
#02-07-30-008: Vibration Felt After Shifting Into Drive or Reverse (Verify Rear Transmission Mount Shim Thickness, Resettle Powertrain Mounts, Replace Rear Transmission Mount If Necessary) - (Feb 7, 2002)
Subject:Vibration Felt After Shifting Into Drive or Reverse (Verify Rear Transmission Mount Shim Thickness, Resettle Powertrain Mounts, Replace Rear Transmission Mount if Necessary)
Models:2001 Buick LeSabre
Built Prior to VIN Breakpoint 1U168687
Condition
Some customers may comment that upon acceleration after shifting the vehicle into drive or reverse, a vibration can be heard and felt in the steering wheel, seat and floor.
Cause
This condition may be due to the rear transmission mount grounding out, frame alignment to the body or a “loaded” powertrain mount.
Correction
Follow the service procedure below to diagnose and repair effected vehicles.
Rear Transmission Mount Inspection
1. Raise and support the vehicle. Refer to the Lifting and Jacking the Vehicle in the General Information sub-section of the Service Manual (SI2000 Document ID # 439413).
2. Remove the plastic clip from the power steering gear heat shield.
3. Remove the power steering gear heat shield retaining bolts.
4. Remove the power steering gear heat shield.
5. Measure the thickness of the rear transmission mount shim (3) located between the mount bracket (1) and the top of the mount (4) using a 5 mm (3/16 in) drill bit (2).
6. If the shim (3) thickness IS EQUAL TO OR GREATER THAN 5 mm (3/16 in), perform the Frame Alignment and Engine Mount Neutralization procedures listed below.
7. If the shim (3) thickness IS LESS THAN 5 mm (3/16 in), replace the rear transmission mount (4), P/N 25723646, using the service procedure listed below.
Rear Transmission Mount Replacement
1. Support the rear of the engine frame with suitable adjustable jack stands.
2. Remove the four rear frame mounting bolts.
3. Lower the rear of the cradle with an adjustable jack stand.
4. Remove the three nuts and two bolts retaining the rear transmission mount.
5. Remove the rear transmission mount and discard.
6. Replace the rear transmission mount with P/N 25723646.
Important: Hand tighten the lower mount fasteners at this time. They will be tightened in the Engine Mount Neutralization Procedure.
7. Install the three nuts and two bolts retaining the rear transmission mount and hand tighten.
Tighten
Tighten the two upper rear transmission mount to the bracket nuts to 50 N·m (37 lb ft).
8. Install the power steering gear heat shield.
9. Install the power steering gear heat shield retaining bolts.
Tighten
Tighten the power steering gear heat shield retaining bolts to 9 N·m (79 lb in).
10. Install the plastic clip to the power steering gear heat shield retaining the wire harness.
Important: Raise the rear of the frame with the adjustable jack stands and hand tighten the frame mounting bolts at this time. They will be tightened in the Frame Alignment Procedure.
11. Install the four rear frame mounting bolts and hand tighten.
12. Proceed to Frame Alignment and Engine Mount Neutralization Procedures below.
Frame Alignment
1. Inspect the frame to body alignment by inserting a 16 mm (5/8 in) guide pin or drill bit into the frame-to-body guide pin holes (1) in the rear of the frame. If the guide pins do not visually align perpendicular to the floor, the frame is not correctly aligned with the body. Proceed with the next step. If the frame alignment is correct, proceed with Step 9.
2. Remove the retainers from the front air deflector.
3. Remove the front air deflector.
4. Support the engine frame with suitable adjustable jack stands.
5. Loosen, DO NOT REMOVE, the six (two if you replaced the mount) frame mounting bolts.
6. Using the 16 mm (5/8 in) dowel pins or drill bit in the alignment holes (1), align the engine frame (2) with the body.
7. Install the front air deflector.
8. Install the front air deflector retainers.
9. Tighten the frame mounting bolts.
Tighten
Tighten the frame mounting bolts to 191 N·m(141 lb ft).
10. Remove the jack stands.
1. Loosen, DO NOT REMOVE, the lower nut and two bolts retaining the rear mount (if the rear mount was not replaced in the above Rear Transmission Mount Replacement procedure).
2. Loosen, DO NOT REMOVE, the lower nut retaining the front mount to the frame.
3. Loosen, DO NOT REMOVE, the lower nut retaining the right mount to the bracket.
4. Loosen, DO NOT REMOVE, the lower nut retaining the left mount to the bracket.
5. Lower the adjustable jack stands allowing the frame to lower to a position that the bottoms of the mounts no longer touch the frame or the mount brackets.
Important: The mount fastening sequence is critical. Tighten the right mount first, the left mount second, the front mount third and the rear mount last.
6. Raise the frame with the adjustable jack stands and tighten the nuts as follows:
Tighten
6.1. Tighten the right mount nut to 70 N·m (52 lb ft).
6.2. Tighten the left mount nut to 70 N·m (52 lb ft).
6.3. Tighten the nut retaining the front mount to the frame to 70 N·m (52 lb ft).
6.4. Tighten the rear mount bolts and nut to 50 N·m (37 lb ft).
7. Lower and road test the vehicle.
8. Align the vehicle if necessary. Refer to Measuring Wheel Alignment in the Wheel Alignment sub-section of the Service Manual (SI2000 Document ID # 668446.
Parts Information
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
Old 02-14-2013, 04:15 PM
I didn't have the vibration before replacing the worn out mounts, and I didn't mess with the frame to body mounts. I'll crawl under it and check for spacers/shims on the rear mount, I don't think the new mount had any.
Old 02-15-2013, 10:14 AM
Thanks gmtech for the info. I found no spacers on the rear mount so I removed them off the old mount and installed on new. Loosened all mounts and re-tightened in reccomended sequence.
The vibration is still there. I see the serpentine belt tensioner bouncing alot while engine is running, I've got a new belt coming and I'll see if that smoothes out the tensioner & possibly the vibration I'm feeling.
Thanks,
Old 03-12-2013, 05:22 PM
donferr785 donferr785 is offline
I just finished replacing my motor mounts as you did and am experiencing the same vibration and noise rumble. I have read the TSB and am going to try and perform it but hesitate to buy the new rear transmission mount for 86$. Is there any news on your situation? What have you done and did you find something that worked? Thanx in advance.
Old 03-12-2013, 05:39 PM
Rockauto.com has good prices on parts. I cleaned the IAC (Idle air control) and that seemed to help a little. My daughter's driving it now so I'm not to concerned about it. Otherwise i'd probably replace the IAC in hopes of raising the idle a little which seems to smooth things out.
