Old 02-13-2013, 07:21 PM
jman401 jman401 is offline
Automatic door doesn't work/passenger
Hi,
My 2005 town and country with 120,000 miles passenger door has stopped working. I've fixed the wiring in the track previously and that is still in tact. It worked for a while after that fix but stopped again. It makes a click when you hit the button but nothing happens. Is my next step to fix that actuator? Can this part be tested? They run about $70 at the store. Thanks!
Old 02-14-2013, 12:39 AM
hundahunta hundahunta is offline
Re: Automatic door doesn't work/passenger
maybe the harness failed again...can the door open manually. If so open it all the way and close it with the switch and see if it locks automatically competely
Old 03-07-2013, 11:54 AM
tacomabobd tacomabobd is offline
Send a message via Yahoo to tacomabobd
Put a volt meter across the motor. When you activate the door, you should get 12 volts. If you do get the 12 volts and nothing happens, replace the motor. If you do not get the 12 volts, trace the wires back till you find the problem.
Old 03-07-2013, 01:20 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
They sell replacement door wire harnesses on the net.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 03-23-2013, 08:46 PM
jimslaid jimslaid is offline
If it only clicks, then I think that the motor is not getting enough power.
