Go Back   Automotive Forums Car Chat > Buick > Century
Old 02-12-2013, 12:22 PM
ldogg63851 ldogg63851 is offline
Ignition switch replacement
My 2003 Buick Century will not start. If you turn the key the lights and radio work just fine but as soon as the key is turned to start the car, all lights go away and car does not attempt to start or even make any noises at all. I checked all fuses under the hood and even swapped the relays with known good relays. I checked battery voltage 12.5 and I am also getting the same voltage to my alternator and starter. I used a screwdriver to jump across the starter and the starter works. Any suggestions? I wanted to try to replace my ignition switch. Does anyone have instructions on how to replace it or maybe a video.
Old 02-12-2013, 01:06 PM
tempfixit tempfixit is offline
Re: Ignition switch replacement
Sounds to me like a bad starter solenoid or battery cables need to be cleaned. Have youtested the voltage at starter while someone has turned the key to start position?
Old 02-12-2013, 05:12 PM
Yes I tested it with the key in the start position. I forgot to mention I cleaned the battery cables.
Old 02-13-2013, 09:21 AM
Tech II Tech II is offline
If you tested the purple wire going to the starter solenoid(I rather use a test light), with the key in the crank position, and the light was bright, but the starter didn't crank, then you need a new starter, not an ignition switch.....
If you don't have power at the purple wire, then you need to check the Security light on the dash, to see if the light goes out after 3 seconds, with the key in the "on" position(do not crank)......
Tags
2003 , buick , century
