Go Back   Automotive Forums Car Chat > Cadillac > Seville
Old 02-12-2013, 09:59 AM
ryanusrey2012 ryanusrey2012 is offline
1995 Cadillac Seville SLS second gear start
My 95 Seville SLS has been starting off in second gear and will not use first gear in any circumstance. I hooked it up to the tech 2 and received data showing that there were faults in both quad driver 1 and 3. also in the drive position shift solenoid a was not engaging. to single out the solenoid I used the scanner to command the vehicle in first gear and it went right in but when i leave the program it is back to second gear start. Now I do not want to single out the PCM and the car does have a throttle switch shorted code, a PRNDL switch failure, and a MAP sensor code. All I need help with is which issue should be my main concern.
Old 02-12-2013, 10:00 AM
Re: 1995 Cadillac Seville SLS second gear start
Oh and for additional info this is the 4T80E trans and the car has 202k miles and has the LD8 4.6L SFI
Old 02-18-2013, 01:49 PM
okay i found out what it was it was an ABS fault in a faulty speed sensor tricking the PCM into thinking that the cars wheels are slipping and defaulting to second gear start to try and suppress this slipping
Old 03-15-2013, 04:02 PM
Seville SLS Seville SLS is offline
The ABS can be tricky man, glad you finally got it to work. I haven't had too many problems with mine. However mine is a 96 not a 95 and only has 21 thousand miles.
How much have you put into your car repair wise?
Seville SLS
Tags
driver , quad , shift , solenoid
