Old 02-10-2013, 09:27 PM
bmklawt bmklawt is offline
Need starter gear tooth geometry
Can anyone tell me what the pressure angle and diametral pitch is on the gear of an automotive starter.
Working on a project and need to find a 6" diameter gear that will mesh with the gear on a starter. Trying to make a starter that will start my dads old 1929 John Deere tractor.
Your help is greatly appreciated,
Bruce
Bruce
2014 Toyota Camry Hibrid
2005 Silverado Z71 5.3L
1997 Grand Caravan 3.3L
1997 Dodge Ram 1500
Old 02-12-2013, 07:59 AM
vgames33 vgames33 is offline
Re: Need starter gear tooth geometry
It will likely depend on what starter you use. Some flywheels have more teeth than others.
Old 02-12-2013, 12:43 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Do you have a donor starter that you want to use? If so, you could calculate the gear size/pitch. McMaster-Carr probably has a section explaining how to measure the gear and listing of available gears in the size/pitch you need.
-Rod
