Old 02-10-2013, 05:37 PM
lovegt40's Avatar
lovegt40 lovegt40 is offline
ItaloSvensk
alternative flocking anyone?
isnt there any other home made method to make flocking for carpets?
I dont have any at home and cant find one aroudn in the color I like.
checked some nice tutorials in the forum:
http://www.automotiveforums.com/vbul...d.php?t=554434
but they use anyway something already done.
Just wonder if there is a way to make something realisting with "emergency" stuff
thnx
Paolo - LoveGT40 Modelworks
website www.alsoldatino.com
my YT channel : https://www.youtube.com/channel/UCIp..._as=subscriber
FB: https://www.facebook.com/alsoldatino
Old 02-11-2013, 06:45 AM
cjsbosox's Avatar
cjsbosox cjsbosox is offline
Re: alternative flocking anyone?
I use felt paper from local hobby stores like Hobby Lobby or Michael's. Make a template, cut out what you need. Before putting it in, soak in water and 15 seconds later peel off the paper backing. There will be some backing left that can be removed the same way, but at that point its optional since the material will be thin enough at that point. At that point its ready to be glued in place. I will post pics in my latest WIP
Hope that helps.
Another day on the job!
The Following User Says Thank You to cjsbosox For This Useful Post:
lovegt40 (02-12-2013)
Old 02-11-2013, 10:13 AM
nugundam93 nugundam93 is offline
Blarg! Wort Wort Wort!
grind up some florist's foam (or whatever that thing is caller where you can stick stems onto it and holds water) and then sprinkle them on a surface with white glue, then scrape off the excess once dry. it has to be ground real fine though.
so okay, this isn't something that can be used in a common emergency (who else stocks up on them? hahaha) but still, it's an alternative
olly olly oxen free
Old 02-11-2013, 12:04 PM
das_auto's Avatar
das_auto das_auto is offline
Hey Paolo!
You can use ordinary wheat flour (Vetemjöl på svenska). You put down some enamel clear varnish like Humbrol or similar and gently blow the flour from your hand onto whatever is getting flocked. It´s quite messy and should really be done outside. I´ve tried it a couple of times with pretty good results.
When dry, primer and paint like ordinary. Preferably with airbrush to prevent the paintbrush from ruining the finish.
Cheers!
Emil
The Following User Says Thank You to das_auto For This Useful Post:
Old 02-11-2013, 01:59 PM
rallymaster's Avatar
Paolo, take a look in my California build, I use vaccum cleaner filter material and it's really satisfying to me.
I also used some in my GT3, running WIP link is in the tribute thread.
Let me know if you want to test some.
California
GT3
Phil
The Following User Says Thank You to rallymaster For This Useful Post:
Old 02-12-2013, 12:30 PM
kemilk kemilk is offline
I use an embossing powder. It's real fine and works great as carpets or the material on the dashboard of a race car.
The Following User Says Thank You to kemilk For This Useful Post:
Old 02-12-2013, 03:23 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Another option is moleskin- self adhesive felt used to cover up blisters. Cut it to whatever shape you need, color it (paint, ink, and even markers work great), and remove the backing and stick it in place.
PHOTOBUCKET SUCKS
Old 02-13-2013, 10:00 AM
exhaust smoke's Avatar
exhaust smoke exhaust smoke is offline
I use self adhesive velour from arts and crafts shops used for making the lining in jewelry boxes.
Old 02-15-2013, 06:27 PM
Lambo003's Avatar
Lambo003 Lambo003 is offline
If I'm in a pinch I'll simply use carpet samples from Home Depot or the like.
Sure it may be a little out of scale . . . but nothin' looks like real carpet like REAL carpet!. . .
Chuck
Old 02-16-2013, 03:56 AM
Hermanzini Hermanzini is offline
That looks most impressive!!!
Old 02-17-2013, 06:33 AM
drunken monkey's Avatar
Razor Sharp Twit
very limited colour range but I've used these quite often.
It takes quite a few coats to get good coverage but it gives a nice texture and also takes to be sprayed different colours afterwards quite well too although you do lose some of the furriness.
AF's Guidelines
Read them.
The Following User Says Thank You to drunken monkey For This Useful Post:
lovegt40 (02-17-2013)
Old 02-17-2013, 08:28 AM
proosen's Avatar
proosen proosen is offline
I've given up on flocking as I always made a mess with it in some way or another.
Came up with the idea of using baby wipes instead, and with some white glue and a gentle shower with the airbrush it's possible to get whatever colour you want.
Take a look at my Impala build and see for your self how I did it and how it came out.
I was really surprised of the look of it, almost like a scale carpet when painted.
Lycka till! (aka good luck in sweden)
Niclas
The Following User Says Thank You to proosen For This Useful Post:
cjsbosox (02-22-2013)
Old 02-17-2013, 12:36 PM
lovegt40's Avatar
ItaloSvensk
Tack Niclas,
Your impala looks very nice. all those idea are giving me the inspiration to try all.
another swedish friend helped me with some flocking.. (tack Emil).will try all ways possible soon
Old 02-28-2013, 12:56 PM
JUSTK7200 JUSTK7200 is offline
Hi there,
Greeting from Trinidad and Tobago. I have used Rustoleum Textured spray paints. They can be airbrushed after drying for the color you want. Just mask the areas you don't want to paint with masking tape and as a substitute for liquid masking, I use Elmer white glue(PVA glue). Hope this was helpful.
Old 02-28-2013, 08:46 PM
andybmw7272 andybmw7272 is offline
I recently have been using embossing powder with very pleasing results.
however, I had forgotten I had used paper towels once before until proosen mentioned the baby wipes trick.
Below is the carpet in my cobra. I used paper towels, the expensive kind, "Viva" as sold here in the United States. I got a flat paintbrush, some elmers glue all, and painted it down (kind of like paper mache) and then painted it flat black.
I think this would only look good with black as lighter colors will highlight the inaccurate texture, but maybe it is worth a try with some other colors. As I say that, I did it with my very first model, too. A 33/34 ford that I have pics of.
Either way, it might be worth a little experimentation.
I hope it helps!
Andy
