Old 06-06-2003, 11:31 PM
KRAZYMATT36 KRAZYMATT36 is offline
Factory Ride Hight Adjustment
Is There A Way I Can Raise Or Lower The Factory Hight Of My Truck Using The TOrsen Bars Or Whatever They Are? i Have A 99 2wd Extended Cab Silverado 1500. If Anyone Knows Anything About It Let Me Know A How To With Pictures Would Be Even More Better! Thanks
-KRAZYMATT
Old 07-01-2003, 11:48 PM
BigB00 BigB00 is offline
Torsion bar crank
Here is a site on how to crank the torsion bars on a Ranger (yeah yeah, I know it's a ford.) It's the same as on your Silverado. I'm thinking about doing the same thing to my 2000 Silverado 1500 4X4.
http://www.therangerstation.com/TorsionBar.html
Old 09-14-2003, 11:59 AM
trukdryver trukdryver is offline
Send a message via Yahoo to trukdryver
KRAZYMATT-
If your truck is a 2wd, you have front coil springs--NOT torsion bars. There are lots of ways to change ride height in 2wd trucks... you could go with drop spindles, spring spacers, air ride, or even replace the springs altogether. If it's a drop you're looking for, I'd recommend NOT cutting the springs.... it's cheap, but your ride and handling will suffer dramatically, and I personally think it's just plain unsafe.
Old 04-12-2004, 10:46 PM
01 Bowtie 01 Bowtie is offline
Re: Factory Ride Hight Adjustment
If your truck is a 4x4 then you can gain up to about 1 1/2 inches by cranking up your torsion bars BUT don't do it! It screws up your ride (Makes it rough) Limits your suspension travel & is bad for your tires.
Old 04-13-2004, 10:25 AM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Do you want to lower or raise it. Don't do anything cheap when dropping or raising it'll be worse in the long run.
*Under Construction - New sig to debut*
Old 04-13-2004, 12:49 PM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: Re: Factory Ride Hight Adjustment
I've had mine cranked since it was new (Not to the extreme, just enough to make me happy), no problems. I turned a buddies 7 rounds 2002 HD and he sees no problems. It all depends on what makes you happy.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 02-07-2005, 08:18 PM
BAKERBAKER BAKERBAKER is offline
-KRAZYMATT
YOU CAN RAISE THROUGH THE TORSION BARS I DID ON MY 94 K 1500 AND IT TOED THE FRONT TIRES AND I ATE FRONT TIRES IN ABOUT EVERY 15,000 MILES I TRIED TAKEN IT BACK COULDENT GET IT RIGHT
HAD TO TAKE TO THE SHOP THEY FIXED SOME BUT IT TIRES NEVER WORE RIGHT AGAIN. ALSO THE FRONT SHOCKS COULDNT KEEP UP WITH BOUNCE IN THE FRONT TRUCK WOULD BOUNCE SEVERAL TIMES NOT FROM BEING LOOSE BUT FROM BEING TO TIGHT
