Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 02-09-2013, 02:34 PM
TCHRISD TCHRISD is offline
96 LSS throwing codes.....
I have a 96' LSS throwing P1133 and P1406.
I have changed the O2 sensors about 5 months ago.
Can something be causing these codes to appear?
Old 02-09-2013, 06:37 PM
maxwedge maxwedge is online now
A990 racer
Re: 96 LSS throwing codes.....
Yes something is causing these codes, have done a google or site search for the definitions?
Old 02-10-2013, 09:32 AM
Yes , it appears they are electrical codes for bank 1 O2 sensor and pintle position sensor for EGR.
Old 02-10-2013, 11:09 AM
Tech II Tech II is offline
The O2 sensor code can be, under the right conditions, be caused by a bad EGR....
The only way to know for sure, is with a scan tool.....
The scan tool is needed to check O2 sensor activity, especially on startup to see if the heater circuit is helping it to start quicker......and if there are sufficient cross counts.....
Also need to check the EGR pintle position with scan tool to see if it is stuck open or if there is a discrepancy in position between commanded position and actual position....
