Old 02-04-2013, 11:30 PM
lwalls lwalls is offline
Unhappy whistling noise around the filter /fuel lines?
2003 trailblazer Lt . when the motor is running the high pitch noise is coming from the fuel filter / fuel line area, if i crawl under there whil itd running i can get it to change noises when im grabbing the lines and filter but but it seems like it changes thje most when i mess with the hose where you hook a pressure gage up to it or bleed it
Old 02-05-2013, 04:35 AM
Schurkey Schurkey is offline
Re: whistling noise around the filter /fuel lines?
Noise from fuel filter area? Any chance the filter is partially-plugged leading to pressure drop and turbulence?
"I"'would start by checking fuel pressure; and check my notes and receipts to see when the filter was last replaced.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
The Following User Says Thank You to Schurkey For This Useful Post:
lwalls (02-08-2013)
Old 02-07-2013, 08:03 AM
j cAT j cAT is offline
Originally Posted by lwalls View Post
2003 trailblazer Lt . when the motor is running the high pitch noise is coming from the fuel filter / fuel line area, if i crawl under there while it's running i can get it to change noises when I grab the lines and filter ,but but it seems like it changes the most when I, mess with the hose where you hook a pressure gage up to it or bleed it
I have seen that when the fuel filter restricts flow the pump gets louder. could also be restricted return line etc.
The Following User Says Thank You to j cAT For This Useful Post:
lwalls (02-08-2013)
