Old 06-06-2003, 11:19 PM
jameshall jameshall is offline
Question rev limiter ?
My 97 grand am cuts out when i rev the engine around 4000 is there a rev limiter on the engine ?? has the Quad 4 engine.
Old 06-08-2003, 05:27 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Yes there is a limiter on your engine! All GM cars and trucks have them built into the software of the PCM. Depending on your speed rating of your tires determines the fuel cutoff RPM.
Old 06-08-2003, 05:30 PM
97gsr's Avatar
97gsr 97gsr is offline
Send a message via AIM to 97gsr
damn bro...you really need to get a honda.. j/p
my rev limit is 8200
ITR inside
Old 06-10-2003, 10:03 AM
'00' GTP '00' GTP is offline
is that when you are in park? usually the revlimiter is alot less when it is in park than when you are moving. if you are going down the road, and put it in neutral, I bet you can get the RPM's higher.
2000 Black 4 Door GTP
3.4" pully
FWI
14.5 stock
2003 Red Accord Coupe
V6 6-speed
car-stats.com saies it runs 14.7
Old 10-02-2003, 07:35 PM
nytlife666's Avatar
nytlife666 nytlife666 is offline
Send a message via AIM to nytlife666
Angry Shut off Rev Limiter
This is for my friend we have no idea how to shut off the rev limiter in his ''97 Grand AM GT any one know how??
Old 10-24-2003, 05:21 AM
monkey84 monkey84 is offline
To turn off the rev limiter=virtually impossible, and stupid
Disabling the rev limiter will allow your engine to run super-high RPM's...that's bad, because it won't be able to handle the extra strain, thus the reason behind the rev limiter...
If you want it to go faster, than you want to disable the speed limiter, which you can usually do with a new ECU chip...not sure where to get those or how much for grand am's...
