1993 Chevy starting problem
I have a 1993 Chevy Silverado rwd automatic 350 5.7. It died on me on the way to work this morning. It slowly lost power and acceleration. The lights and radio all worked. When I tried to restart, it tried to start but then just cranked like it had no fuel or spark.
I had it towed home and checked the following things. I removed the fuel filter, it is clear. I verified that the fuel pump was working by turn the key to the on position while the filter was off. Good stream of fuel. I verified that there was fuel to the TBI. Good spray while cranking. I verified that there was spark by pulling a plug out, connecting to the wire and cranking the engine. Spark seemed weak but there was spark. The front plugs were dry, but the rear plugs, especially #8 was very wet. I verified the timing by pulling the #1 plug, removing the distributor cap and checked the rotor position. I bumped the engine to get the #1 piston to the top of the cylinder and the rotor was point directly at the #1 plug wire. The cap, rotor, plugs and wires are only 1 month old.
I also tried to check the ignition coil by disconnecting the coil wire from coil, and slid the boot back to expose the contact. I held it just of the coil while the engine was cranked, but did not actually see a spark at the coil. I did not hear any arcing. I pulled another plug and checked for spark. Again i had spark. Just seems weak to me.
I am on my way to the auto parts store to get a new coil. Any thoughts as to what else this problem might be? It's going to rain a few days this week here in Houston, so I don't want to ride mike motorcycle in it everyday. I just cleaned it. I appreciate any help you folks can give me. Thanks.
