Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-03-2013, 02:01 PM
dallas121469 dallas121469 is offline
Send a message via Yahoo to dallas121469
Manual Transmission Issue
2007 V6 Mustang Manual Transmission
I recently got stuck in my drive way due to a p*ss poor plowing job by the plow guy. I had to turn the traction control off and aggresively shift transmission between reverse and 1st to rock the car and spin the tires. I eventually got unstuck but now the transmission doesnt feel right. I thought it was the clutch but the issue seems to occur only shifting from 1st to 2nd. The higher gears all seem relatively fine. There is just a catch between 1st and 2nd now that sometimes causes me to not be able to shift into second gear without forcing the shifter down roughly. Is it possible that I just threw something out of alignment inside the transmission itself? It doesnt make the car undrivable but i get ticked every time i drive it knowing that it was fine before the poor plowing job.
Should I even bother having it looked at? I know transmission repairs are expensive.
Thanks for any help on this matter.
Old 02-03-2013, 07:23 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Re: Manual Transmission Issue
This is likely caused by the wear and tear on the clutch while trying to free your car from the snow . Modern clutch systems are hydraulic operated and normally self adjust to compensate for wear ? Could be the wear was sufficient to go beyond the usual wear and maybe the self adjustment feature can't compensate for that ? I'd suggest having a qualified garage look at it . If not , the clutch likely will continue to not operate properly and it will accelerate the wear on the clutch disc . This would necessitate replacement in the near future . I wouldn't necessarily dismiss the possibility that the transmission itself could have been damaged as well ? I think that this 2007 Mustang would be worth spending a little money having an SAE certified mechanic look at it and diagnose and repair it before more damage might occur ! Just my $0.02 and good luck !
" Sometimes I grow so tired "
