Go Back   Automotive Forums Car Chat > Chevrolet > Equinox
Old 02-03-2013, 06:46 AM
trs's Avatar
trs trs is offline
remote range
i have a 2008 equinox, 3.4l. i installed a pionner radio last month, now my remote will not work from far, i talked to a tech at a gm dealership and they said the radio is interferaring with the it, is it possable to move the remote antana to a different spot or what else can i do. thanks
tom
Old 02-03-2013, 09:44 AM
Tech II Tech II is offline
Re: remote range
Hold the remote under your chin(touching it), and press the button on your remote.....be surprised how much the strength/range of the transmitter increases, using your body as a giant antenna....
Old 02-03-2013, 05:50 PM
DeltaP DeltaP is offline
Re: remote range
It practically doubles it.
Old 02-04-2013, 12:22 AM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Re: remote range
It could be just a coincidence that the battery in the remote is starting to get low.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
Old 09-13-2013, 06:37 PM
johnholl johnholl is offline
Re: remote range
I think your correct. Chin thing did nothing. I wonder if they use an available battery inside the key fobs?
Old 09-14-2013, 06:42 AM
Re: remote range
The battery is readily available in local Rite Aid, CVS, Walgreen's, etc.
Separate the two halves..make a note of the position/side of the battery before removing......be very careful of the electrical contacts, they are fragile.....
Old 09-18-2013, 10:19 AM
Ruley73's Avatar
Re: remote range
+1 ^^
The battery you will need depends on the remote, but the vast majority of GM remotes use either a 2032 or 2016 3V lithium ion watch battery.
My rides:
- Steve Smith (Red)
