Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-02-2013, 01:43 PM
WhiteRodeo4x4's Avatar
WhiteRodeo4x4 WhiteRodeo4x4 is offline
2001 V6 Rodeo Question
How many bolts actually holding the intake manifold onto the heads. Are there more inside the plenium when you take the top off or can you remove the unit as one piece to replace the intake manifold gaskets?? Thanks
Old 02-03-2013, 01:37 AM
Cat Fuzz Cat Fuzz is offline
Re: 2001 V6 Rodeo Question
The upper and lower parts of the intake can be removed as one unit. IIRC, there are four long bolts and four nuts, one nut on each corner. The hidden fuel line bracket attached to the back of the intake uses two 10mm bolts.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
