Go Back   Automotive Forums Car Chat > Buick > Regal
Old 02-01-2013, 02:09 PM
johntoolman117 johntoolman117 is offline
How do I replace rear spark plugs on a 1994 Buick Regal
Im replacing spark plugs on my grandma's 1994 Buick Regal and there is no way I can reach the rear spark plugs...What gives? Do she have to take it in?
Old 02-01-2013, 11:53 PM
Blue Bowtie's Avatar
Registered Offender
Re: How do I replace rear spark plugs on a 1994 Buick Regal
191 Chevy V6 or 231 Buick?
Old 02-02-2013, 09:12 AM
brcidd's Avatar
brcidd brcidd is offline
Have you tried tilting engine forward- by releasing upper dogbone engine mounts and reattaching to engine tilt holes? This gives you enough room to get in behind engine. That's the way I would do it- as designed for it.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 02-04-2013, 11:31 AM
The engine is designed to rotate?
Old 02-04-2013, 01:23 PM
brcidd's Avatar
For the chevy 3.1L engine- step number two in All Data says to rotate engine- so yes, it rotates. Did grandma have a 3.8L? supercharged?
'99 GMC Yukon
Old 02-04-2013, 02:00 PM
Tech II Tech II is offline
Yes, you can rotate either the 3.1/3.4 or 3.8......
Remove the two upper dog bones in the front, make sure e-brake is applied, have tranny in neutral(rotates easier).....
You can physically rotate the engine forward, and wedge a block of wood in a convenient area of the back against the firewall, to keep it forward.....
As for removing the plugs, sometimes it's hard to remove the wires........need to break them free by rotating the boot in both directions, before pulling......damage can be done to the wires during removal, so if old, just replace them.....
As for the plugs, a double swivel(basically, a "ball" universal, mounted on another one) with a spark plug socket and extension, gets in there easily....the double swivel lets you get in at any angle, as opposed to a single universal.....
Old 02-04-2013, 05:29 PM
brcidd's Avatar
I've never wedged the wood behind engine- heck the dogbones have the "rotated forward" holes in them. Just stick the mounting bolt you took out of the dogbone in one or both of those- as designed.
'99 GMC Yukon
Old 02-05-2013, 05:05 PM
Yes you can do that......lot easier just putting a block of wood(I use 4x4 blocks that I use to block wheels) than lining up that hole......for the guys who have every tool ever made, there is a tool that mounts in place of one of the dog bones, and has a bolt you turn that pulls the engine forward......
Tags
buick , plugs , regal , repair , spark
