Go Back   Automotive Forums Car Chat > Jeep > Liberty
Old 01-29-2013, 10:04 PM
tyler618 tyler618 is offline
2006 Liberty code p0206
This only occurs when I restart the Jeep within an hour of shutting it off. If I wait at least an hour it runs fine. If I start 15 minutes or so after shutting it off I'll get the p0206 and p0306 codes an it misfires. Then I clear codes wait an hour and it runs with no issues. So when I take the jeep anywhere I have to make sure I'm going to be there a while. I changed the plus in the summer and also swapped coil plug on #6 but when it happens is always on #6. Any ideas?
Old 01-30-2013, 06:17 PM
dagwan11 dagwan11 is offline
Re: 2006 Liberty code p0206
DTC P0206 Injector 6 Control Circuit
Refer to Fuel Injectors
Circuit Description
The PCM controls the fuel injectors by using an ignition feed driver and ground circuit within the PCM. The driver has the ability to detect an electrical malfunction in the ignition feed or ground circuit. If an electrical malfunction occurs in the fuel injector circuit for engine cylinder #6, the ignition feed driver signals the PCM to set DTC P0206.
Conditions for Running the DTC
The engine is running.
Conditions for Setting the DTC
  • The PCM detects an electrical malfunction on the injector circuit for engine cylinder #6 for longer than 30 seconds.
  • The condition is present for at least 30 seconds.
Action Taken When the DTC Sets
  • The PCM will illuminate the MIL during the second consecutive trip in which the diagnostic test has been run and failed.
  • If the electrical malfunction could lead to possible catalyst damage, the PCM will immediately flash the MIL while the fault remains at catalyst damage levels.
  • The PCM will disable TCC operation.
  • The PCM will store conditions which were present when the DTC set as Freeze Frame and Fail Records data.
Conditions for Clearing the MIL/DTC
  • The PCM will turn the MIL OFF during the third consecutive trip in which the diagnostic has been run and passed.
  • The history DTC will clear after 40 consecutive warm-up cycles have occurred without a malfunction.
  • The DTC can be cleared by using the scan tool Clear Info function or by disconnecting the PCM battery feed.
Diagnostic Aids
The misfire history counter may be useful in determining which injector circuit is malfunctioning. If DTC P0300 was set, look at the Misfire Hist # display for each cylinder. The largest value stored in the misfire history counters will indicate the location of the malfunctioning injector circuit or injector.
Check for the following conditions:
  • Poor connection at the PCM or fuel injector. Inspect harness connectors for backed out terminals, improper mating, broken locks, improperly formed or damaged terminals, and poor terminal to wore connection.
  • Damaged harness. Inspect the wiring harness for damage.
Reviewing the Fail Records vehicle mileage since the diagnostic test last failed may help determine how often the condition that caused the DTC to be set occurs. This may assist in diagnosing the condition.
Test Description
Number(s) below refer to the step number(s) on the Diagnostic Table.
  1. Checks for malfunctioning fuel injector control circuit or ignition feed wiring.
  1. Checks for a malfunction in the fuel injector ignition feed circuit.
  1. Checks for a short to ground in the injector control circuit.
  1. Checks for an open in the fuel injector control circuit.
  1. This vehicle is equipped with a PCM which utilizes an Electrically Erasable Programmable Read Only Memory (EEPROM). When the PCM is being replaced, the new PCM must be programmed.
DTC P0206 - Injector 6 Control Circuit
Step
Action
Value(s)
Yes
No
1
Was the Powertrain On-Board Diagnostic (OBD) System Check performed?
2
With the engine idling, monitor Specific DTC info for DTC P0206 on the scan tool. Does the scan tool indicate DTC P0206 failed this ign?
3
  1. Turn ON the ignition switch.
  2. Review and record scan tool Fail Records data.
  3. Operate the vehicle within Fail Records conditions.
  4. Monitor Specific DTC info for DTC P0206 on the scan tool.
Go to Diagnostic Aids
4
  1. Turn OFF the ignition switch.
  2. Disconnect the PCM.
  3. Turn ON the ignition switch.
  4. Using a J 39200 DMM, measure the voltage between the cylinder #6 fuel injector control circuit at the PCM connector and ground.
Does the cylinder #6 fuel injector control circuit measure near the specified value?
B+
5
Check the fuel injectors. Refer to Fuel Injector Coil Test - Engine Coolant Temperature (ECT) Between 10-35 Degrees C (50-95 Degrees F) or Fuel Injector Coil Test - Engine Coolant Temperature (ECT) Outside 10-35 Degrees C (50-95 Degrees F) . Are the fuel injectors OK?
6
  2. Disconnect the cylinder #6 fuel injector.
  4. Measure the voltage between the cylinder #6 fuel injector control circuit at the PCM connector and ground.
0V
7
  1. Check for the following conditions:
    • The ignition feed circuit in the wire harness between the fuse and the cylinder #6 fuel injector for an intermittent open.
    • The cylinder #6 fuel injector control circuit between the PCM and the injector for an intermittent open or short to ground.
  2. If a problem is found, repair as necessary. Refer to Wiring Repairs .
Was a problem found?
8
  1. Check for poor terminal connections at the cylinder #6 fuel injector connector.
  2. Check the cylinder #6 fuel injector control circuit for poor terminal connections at the PCM connector.
  3. If a problem is found, repair as necessary. Refer to Wiring Repairs .
9
  2. Disconnect the cylinder #6 fuel injector connector.
  4. Measure voltage between ignition feed circuit at the cylinder #6 fuel injector connector and ground.
Does the ignition feed circuit measure near the specified value?
B+
Probe the cylinder #6 fuel injector control circuit at the cylinder #6 fuel injector harness connector with a J 34142-B test lamp to B+. Is the test lamp ON?
  2. Install a fused jumper between the cylinder #6 fuel injector control circuit and the ignition feed circuit at the cylinder #6 fuel injector harness connector.
  4. Probe the cylinder #6 fuel injector control circuit at the PCM connector with a J 34142-B test lamp to ground.
12
  1. Check for a poor terminal connections at the cylinder #6 fuel injector connector.
13
Locate and repair open in the cylinder #6 fuel injector control circuit. Refer to Wiring Repairs . Is action complete?
14
Locate and repair open in the cylinder #6 fuel injector ignition feed circuit. Refer to Wiring Repairs . Is action complete?
15
Locate and repair short to ground in the cylinder #6 fuel injector control circuit. Refer to Wiring Repairs . Is action complete?
16
Locate and repair short to voltage in the cylinder #6 fuel injector control circuit. Refer to Wiring Repairs . Is action complete?
0v
17
Replace malfunctioning fuel injector(s) Refer to Fuel Injector Replacement . Is action complete?
Replace the PCM.
Important:
The replacement PCM must be programmed. Refer to PCM Replacement/Programming .
Is action complete?
19
  1. Review and record scan tool Fail Records data.
  2. Clear DTCs.
System OK
Old 02-02-2013, 01:01 PM
Did you find the fault or is it still broke?
