Old 01-28-2013, 09:51 PM
lbranham1101 lbranham1101 is offline
harmonic balancer
I'm replacing the harmonic balancer tomorrow, few questions I have before starting. Any idea of what mm the belt tensioner is and the bolt on the BB?
And what is the procedure for removal and installation of the HB? I bought the part and a puller. I was told the head and timing cover MUST come off??? It seems I have perfect accessibility to it as is, and the motor is in time now so. Help with these questions would be great, and if you have additional info or tricks,elaborate please and thank you
Old 01-30-2013, 05:38 PM
Tech II Tech II is offline
Re: harmonic balancer
What year and engine?
You do not have to remove a timing cover/head to replace a harmonic balancer....
Old 01-30-2013, 06:00 PM
Ok so i got it done, it would have only taken about an hour if parts store would have given me the right HB, caused me to break the CPS but they replaced the sensor and gave me the right part so. Any who, impact wouldn't touch the bolt, had a 2ft breaker bar and veins popping out my forehead to get it off. But its all fixed now
Old 01-31-2013, 01:10 PM
rkvons's Avatar
rkvons rkvons is offline
For future reference, you should familiarize yourself with the "Put a ratchet on the HB bold head and lay handle of ratchet across frame member and then bump the starter" technique for loosening that bolt.
Old 01-31-2013, 01:19 PM
That just seems a bit dangerous but I did consider it.
Old 01-31-2013, 03:23 PM
DeltaP DeltaP is offline
That's a risky trick...should only be done by experienced pros. But then they would probably have the right tools. Do it wrong and you can do a lot of damage not to mention getting hurt.
Old 02-04-2013, 01:19 PM
rkvons's Avatar
That procedure is all over this forum. I'm surprised you are discouraging it now.
Old 02-04-2013, 03:10 PM
I know that "trick" and I didn't learn it here. For someone with limited automotive repair experience it can be dangerous and can do damage. Do it wrong and you'll be wearing a breaker bar for dentures,knock an eye out,bust yer nose,etc. On the mechanical damage side how'd you like to break off the crankshaft bolt just for starters?
Old 02-20-2013, 08:13 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
i doubt you see this posted in the Grand Am section!
Ive seen some people try this and get seriously hurt, while causing damage to the engine crank.
thats always fun, replacing the crank.
1999 Grand Am SS 3.4 OHV
