Old 01-27-2013, 09:19 PM
lumina_98 lumina_98 is offline
98 lumina oxygen sensor post cat removal
It is so tight might have to take it somewhere to get it removed. I've tried a torch and penetrating oil. I can't get an impact wrench on it. Any tips greatly appreciated. It probably needs to be on a lift and a 3 foot long cheater bar cranking on it. I can't get leverage under the car just up on ramps.
Old 01-28-2013, 03:22 AM
Schurkey Schurkey is offline
Re: 98 lumina oxygen sensor post cat removal
First Guess: Threads are seized. Once you get it out, you'll have to re-tap the threads in the pipe before cranking the new sensor in.
Common as dirt. No amount of penetrating oil is going to help. Heat might--or might not--help.
Things get too bad, there won't be enough left of the bung to re-tap. Then you get to weld a new bung into place.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 01-28-2013, 09:55 AM
Tech II Tech II is offline
You can spray penetrant, like PB Blaster to the threads, several times on a cold exhaust.....give it some time, like an hour.....then start car and get to normal operating temp......shut off.....use a flex head breaker bar(with pipe if necessary) on an O2 sensor socket......work it back and forth....
Should come out.....but it may damage the threads......they are the same thread as a spark plug......so you may need a spark plug chaser.....
As Shurkey said, it's possible the threads could be damaged., so that a thread chaser doesn't help.....
Old 02-12-2013, 11:39 PM
Thanks for the tips. I found another idea and that is hit it with a hammer and chisel. I did that then sprayed more rust dissolver. It came right out and the threads looked perfect.
