Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-27-2013, 05:49 PM
fxrmike fxrmike is offline
99 eclipse trans.
I have a 99 eclipse. The linkage went free on it all of a sudden. Another words it has no tension on it. Any suggestions?
Old 01-28-2013, 09:14 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: 99 eclipse trans.
We need more information. Auto or manual transmission? Did the linkage come loose from the trans or is the transmission linkage moving but more resistance meaning an internal issue?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-30-2013, 07:07 PM
Linkage is connected. A friend of mine checked it. It's a manual transmission. My daughter backed of the parking place and then the shifter swung loosely. It happened instantly and not while going down the road.
Old 02-03-2013, 09:22 PM
Holset powered 420a
Check to make sure the actual shifter arms are moving on the transmission. I have had the clips fall off of the shifter cables and the car wouldnt shift. If your lucky thats what happened. Could be on the shifter bracket under the hood or under the console. If you are sure the linkages are moving correctly then you have issues internally and it will have to be taken out and repaired.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 05-13-2014, 12:11 PM
It appears one of the cables broke. Is the bracket for the cables under the hood or up in the console?
