Old 06-06-2003, 08:18 PM
alky350 alky350 is offline
ID dohc ZC motor
looking at a ZC swap tomorrow...is there anything i can look for to make sure I'm buying a dohc zc motor? what to look for on the block or head?
thanks
:finger: :finger: :bandit: :frog:
Old 06-06-2003, 09:13 PM
Problem_Si Problem_Si is offline
Send a message via AIM to Problem_Si
uh......make sure it has TWO cams....hehehe... j/k...
Aside from the obvious, it should say "ZC" just to the left of the header, where the trans meets the block. Also, make sure everything is there, some things cannot be replaced easily since its a "japan-only" motor.
Good luck!!
There's nary an animal alive that can outrun a greased Scotsman!
DOHC motor swap mack_n_miller69421 JDM Motor & Parts info/chat 5 11-17-2005 05:59 PM
2.0 DOHC motor timing belt/crank problem weberick Contour 4 08-14-2005 05:46 PM
My ZC DOHC Motor WGMotorsports '88 - '91 Civic | CRX | Wagon | Shuttlee 4 05-11-2004 12:47 AM
F/S 1.3 DOHC motor Miguel Gonzales Swift 1 05-21-2003 09:02 AM
DOHC motor? Wants_A_Lude '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 7 03-10-2002 12:36 PM
