Old 01-26-2013, 03:50 PM
junkman1949 junkman1949 is offline
no gas and no fire
I have a 1992 chev tk with 5.7 mtr quit running going down the road changed the computer and control mod checked all grounds and still no fire or gas. Fuel pump pumping gas. Does anyone know what I might try next, this thing is driving me crazy and right now that is a short trip. Any help will be greatly appreciated. thanks
Old 01-27-2013, 10:25 AM
j cAT j cAT is offline
Re: no gas and no fire
what can occur is the ignition switch contacts to the computer/fuel pump could be the problem/worn out. with the igntion sw to on engine off check that you have volts with a volt meter to these circuits. having a manual check that this sw is working correctly. just because the engine cranks does not mean you have a voltage going to the computer/fuel pump etc...
Old 01-27-2013, 01:45 PM
Just checked the voltage have fire on the coil and fuel is pumping gas with the line off. Injectors are not clicking when you turn the switch on though. Thanks for the reply any more suggestions I can try other than match or Bic lighter Thanks again
Old 01-27-2013, 02:57 PM
with the ignition on check for voltage at the injectors. the voltage should be there. then check that the ground side is routed back to the computer. for the injector to open the pcm grounds the return side of injector coil. check the grounds at/for the engine/pcm.
if the injectors do not click when cranking then it is also possible that the cps is messed up/wiring..
Old 01-27-2013, 07:06 PM
Thanks for the info will check everything in the daylight again and see what happens then will give update either way . Thanks again
Old 01-28-2013, 11:03 AM
Checked everything on truck changed computer, module,coil. and finally dist and fired right up. Must have been the the dist, runs great now thanks for the heads up on everything. Might not be long till I need something else Thanks Again
Old 01-28-2013, 11:23 AM
I think that the injector pulse comes from the distributor. so if the distributor was bad then the injectors would not get a operation signal.
with a truck that old you will have more issues . good luck.
Old 01-28-2013, 05:44 PM
2000CAYukon 2000CAYukon is offline
This might help: http://www.slantsix.org/articles/dib...odule-schm.jpg
The pin numbers might not match but the rest is accurate.
//2000CAYukon
Old 01-28-2013, 08:04 PM
Thanks for that info gives me a better understanding of what is supposed to be going on in that thing. Thanks again
Old 01-29-2013, 08:21 AM
something to make sure its in good condition would be the plug wires and the routing of these wires . I would remove each wire and measure resistance and check for any insulation defects. if the resistance or wire condition is with defects replace .
time does effect these electronic devices. bad wires however will cause these devices to fail. replacing all the distributor/ignition components would be the correct repair with the age factor here.
also the MPG is important now with high prices.
Old 01-29-2013, 09:49 AM
Thanks but step ahead I guess replaced them yesterday truck is doing real good right now will have to see how it all pans out. Thanks again for all your help is greatly appreciated.
