Old 01-26-2013, 12:24 PM
ben.na.walker ben.na.walker is offline
Probably a simple solution but wanna make sure.
Alright, dodge grand caravan 3.8. Year: 05'
Just broke 100k miles on this thing, last time i changed the plugs i noticed plug 2 had oil all down in it. I completely forgot about the problem cause i got side tracked with bad sway bar bushings. Anyways, what do you guys think is the cause of the oil leakage? It has gotten so bad that im blowing smoke when its cold, even is warm weather. There is also caked on oil and dirt on a lot of the parts down the front left side of the motor. Blown head gasket? Bad valve cover gasket? I want the best way to approach this before throwing a bunch of money in to it. Note: the smoke is white, but not enough smoke to be a completely blown head gasket.
Old 02-01-2013, 03:23 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Probably a simple solution but wanna make sure.
White smoke says you're burning coolant. Is the reservoir level going down? The oil sounds like a valve cover gasket.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 02-01-2013, 05:27 AM
autoservice2013 autoservice2013 is offline
I think it's the gasket..
Old 02-01-2013, 01:34 PM
tempfixit tempfixit is offline
Do a compression test on all clyinders and if you find any low psi do a leakdown test on those clyinders to see if the head gaskets are bad.
