Old 01-25-2013, 09:36 PM
Robert69 Robert69 is offline
Angry brake lights ??
I have a 98 K1500. The brake lights do not work. The left and right tail lights work as well as the left and right turn signals. The third brake light on the cab also works. Is there a problem with the turn signal switch that may be causing this or is there a simple solution? Please if anyone has had this problem or knows what is wrong and how to fix it please let me know.
Thanks,
Robert
Old 01-26-2013, 09:35 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: brake lights ??
Thanks,
Robert
Check brake light 12 volt feed into and out of turn signal switch.
If it is going into switch and not out left and right rear turn signal the turn ignal switch is bad.
MT
The Following User Says Thank You to MT-2500 For This Useful Post:
Robert69 (01-26-2013)
Old 01-26-2013, 10:59 AM
777stickman 777stickman is offline
Re: brake lights ??
Pickups have a "Stoplamp Relay" in the underhood fuse block. It feeds the power to the turn signal switch for the left & right stop lamps. Also check "STOP" fuse #2 50a in the same place. If these are both good then proceed as MT 2500 says.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
The Following User Says Thank You to 777stickman For This Useful Post:
Old 01-26-2013, 06:10 PM
Re: brake lights ??
Thanks MT & 777,
The fuse and relay are working fine . I checked the signal switch and it was the problem. Changed it and all is fine
Old 01-27-2013, 08:44 AM
MT-2500's Avatar
AF - Advisor
Re: brake lights ??
Thanks MT & 777,
You are welcome.
And thanks for posting back the fix.
Good luck.
MT
Old 02-26-2013, 02:00 AM
Jet Mech Jet Mech is offline
Post Re: brake lights ??
You will want to check the "Mega Fuse" under the hood (engine compartment) and the other fuse locations other than the interior cab fuse box. I have been burned by the simple fix. Convinced it has to be more involved. The schematic for the lighting circuit is the best place to start.
