Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 01-25-2013, 10:32 AM
JohnT396 JohnT396 is offline
2000 Impala 3.4L idle problem
This car has 250,000 miles and has been pretty solid. Recently, I have been having an idle issue in that unless I keep my foot on the pedal, it will stall. I cleaned the throttle body and all the ancillary add-ons yesterday and did not resolve the problem. I was left with simple adjusting the idle screw to raise the RPMs. Easy fix, but I thought the engine controls/computer would make any adjustments needed. So I feel that what ever the problem is, it has not gone away. BTW, there are no codes and no CEL so no clues there. Any suggestions?
Old 01-25-2013, 07:04 PM
maxwedge maxwedge is offline
A990 racer
Re: 2000 Impala 3.4L idle problem
Get that base idle screw back where it was that is factory preset, the tps will have skewed inputs as a result, remove the iac and clean it and the passages, make sure the egr full seats also.
Old 01-25-2013, 08:02 PM
Tech II Tech II is offline
By increasing idle with idle screw, I bet that tranny jumps in gear or has a harsh feel when put into drive....
Hard to believe no codes are set......I have a tool that attaches to the IAC to make it increase and decrease idle, to check the IAC....a bi-directional scan tool is better, since you can increase/decrease idle via the IAC through the PCM....
It's possible the IAC is bad, or the circuit to it is bad, or you have a PCM problem....
These days, it's almost impossible to diagnose problems without a scan tool, even if it's not bi-directional....you can see the rpms and also see the IAC counts, to see if the PCM is commanding the IAC open.....
Old 02-09-2013, 06:46 AM
Bdd8591 Bdd8591 is offline
Have seen this on a couple. Try starting the car and play with the connection at the MAP sensor thats what it was on mine. Worth a try
Old 10-12-2013, 12:55 PM
I just wanted to close this thread and thank you for your suggestions. The ultimate fix was replacing the IAC. Everything is set back to original settings and all is well!
