Go Back   Automotive Forums Car Chat > Buick > Enclave
Old 01-23-2013, 10:41 AM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Steering clunk 09
Found a bad clunk coming from the car when siting still and turning the steering wheel back and forth. Replaced the intermediate steering shaft and it got better but still a clunk.
I checked and found the rack had quite a bit of movement when doing so.
Fix- steering rack bushings.
Dealer wanted $860 for a new rack but I found you can purchase just the bushings for about $15 each.
They are pressed in so you have to remove the rack but it fixed the problem.
I believe the clunk is from the aluminum rack hitting the steel subframe from worn out bushings.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 06-07-2013, 11:09 AM
Impalatech Impalatech is offline
Re: Steering clunk 09
you dont have to remove the rack to service the bushings. there is a trick you can do to get them out and in in about 15-20 minutes.
Old 06-07-2013, 11:35 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Without removing the lines? I am intrigued...
Old 06-07-2013, 12:42 PM
are you a GM tech at a dealer?
Old 06-07-2013, 01:03 PM
i sent you a PM GMtech1.
